Page 718 of 1053 FirstFirst ... 218618668708716717718719720728768818 ... LastLast
Results 7,171 to 7,180 of 10524
  1. #7171
    193 Post(s)
    Quote Originally Posted by Sir Roofy View Post
    New filter don't even clean It
    saw dust for the diff till you get home
    new oil will leak more, saw dust mate works every time in the oil
    Don't worry there was no salvaging this one, reckon half the desert was in there plus half a dozen bugs and some bushes. .
    Hmmm sawdust i like your thinking roofy . . .
  2. The Following User Says Thank You to Rossco For This Useful Post:
    Sir Roofy (29th December 2016)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Emptied the fuel tank finally
  5. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    Sir Roofy (2nd January 2017)
  6. #7173
    195 Post(s)
    Finally got the hydraulic winch connected with new hoses - how prices have gone UP in 15 yrs!, Then, smoke tested the drive belt to the auxiliary pump and re-learnt the lesson about belt pulley alignment, overflowed the hydraulic reservoir, just like the first time, but its super quiet. Need to boost the line speed though as a bit slow in low speed.
    Fixed the leaks on the new rear airbags.
  7. #7174
    Advanced juzzs8's Avatar
    Gold Coast, QLD
    What did you do to your Patrol today!
    Finally installed titan rear drawers after buying them 2 months ago.
    Holes didn't line up great. And workmanship is not super. Going to have to get a grinder to it to get 1 last mounting screw in. Side wings don't seem to fit in too well. But for $380 it's pretty good. Shouldn't complain too much.
    2010 GU7 3.0L CRD
  8. #7175
    How's the serenity boots's Avatar
    Sep 2011
    150 K / 6 month service , engine oil & filter , fuel & air filter , diff oils , grease . Still going strong and a pleasure to drive.
    The price of excellence is dicipline , the cost of mediocrity is dissapointment .
  9. The Following 2 Users Say Thank You to boots For This Useful Post:
    mudski (2nd January 2017), threedogs (3rd January 2017)
  10. #7176
    Quote Originally Posted by juzzs8 View Post
    Yeah I found the exact same with mine. But I paid $700 for them, around 12 months ago. Even at 7hunge I wasn't worried too much. The rhs wing cover doesnt even fit on mine, its about 10mm to long. I also made up three braces for it, Which mount and hold the front of the drawers down as I found out mounting a drop slide on top the entire back section would lift and buckle. Not anymore....
    As for me. I got the two rear barn door windows tinted to 5%. Just to keep the sun off the fridge a little better.
  11. #7177
    Quote Originally Posted by boots View Post
    Long time no speak mate! How are you?
  12. #7178
    Gold Coast, QLD
    Yeh the side wings are well off. Got them in with a lot of force but not great.
    Mine was more issue with left side than right tho.
    Good idea bout the tinting will have to get darker tint I reckon.
    2010 GU7 3.0L CRD
  13. #7179
    I have the two side windows in the rear covered with black plastic corroboard from Officeworks. I think Bunnings sell it too. Was about $8 a sheet. I simply removed the window trim, cut the board to the shape of the window, then put the trim back on, which hold the board in place.
    juzzs8 (3rd January 2017)
  15. #7180
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    Accidentally put in 10ltrs of Premuim Unleaded. Called my diesel mechanic immediately and he said 10ltrs is not enough to hurt the engine. Just put in a diesel injector cleaner and fill it again when used 1/4 tank. Was very hesitant for sure but he's the specialist and so took the risk. All went well, no problems at all.
    That's what I done to my Patrol today. Not good but will be more careful in the future.
  16. The Following 3 Users Say Thank You to Patrol-Guy For This Useful Post:
    juzzs8 (3rd January 2017), katwoman (6th January 2017), mudski (3rd January 2017)
