Results 1 to 10 of 13
Thread: IC upgrade
    Dec 2016
    Yarrabah
    IC upgrade
    Hi
    I have a 2004 zd30 patrol . I'm chasing some advice as to what ic to buy . not rolling in cash atm .
    So something not over the top would be good .
    Thanks Craig
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I have had one of these for three years now with no issues. http://www.brownsradiators.com.au/sh...&id=CACNIS1024
    Reading here Cross Country seem to be popular as an upgrade, but if your stuck for cash a fully welded one should do the job, but make sure you are not getting a cheap and nasty.
    IMO I think the cross country against an OE tigged intercooler is not worth the money.
    Im talking bang for buck$$$, The CC IC will cost $1200 and up and if they are bothered to post
    it.
    A diesel Smart IC will cost about $350- $400 and have a similar outcome.
    My money was spent on the above IC and I love it,
    Make sure you get a pressure tested IC as well,tested to 60psi is ok
    Dec 2016
    Yarrabah
    Hi threedogs
    What you are saying sounds good ,are you running the standard scoop ?
    What boost etc are you running ?
    What is the turn around time for these ic's ?
    Quote Originally Posted by FNqGu04 View Post
    Hi threedogs
    Im running about 20psi boost maybe a tad more,
    Im also running an ARE scoop which I love.
    Turn around was good a few days not sure about
    this time of year.
    Runs great very happy with performance
    Hi threedogs
    Something like this one wont break the bank and
    pressure tested to 55 psi
    http://www.ebay.com.au/itm/TOP-MOUNT...wAAOSwJcZWejqp
    and this boost adaptor when you run a boost gauge
    http://www.ebay.com.au/itm/Patrol-ZD...4AAOSw5cNYLPmR
    If you're going to NADs your motor give @mudski a PM for
    some more info, he'll have what you need from a catch can
    to boost controller.
  8. #7
    Dec 2016
    Yarrabah
    Hi threedogs
    Would you believe I already had that IC saved in my watch list ,the same with the adapter .
    How much did the scoop cost and where from ? I have a mate who is a painter ,so that's all good as far as paint is concerned.
    I would have thought that kind of boost would have thrown a code .
    I'm running 315/75/16 tyres , we have a little "hill" near our place ,it's about 2km to the top . It is 18% to 20% for most of the way ,
    coming over in 3rd for most and 2nd for the steep bit I'm seeing 550 EGT at the most . Is that safe ?
    The IC is leaking a fair bit .
    Craig
  9. #8
    If you IC is leaking this wont be helping your EGTs. The scoop that John and shown a pic of is from a mob called A.R.E. If you can work out their website. Its on there somewhere. Good luck. http://www.are.com.au/index.htm
  10. #9
    you can also get the scoop from Guest 4wd in Fairfield Vic.
    They are not cheap $400 plus
  11. #10
    Dec 2016
    Yarrabah
    Hi
    I got on the are website last nite ,scoop is about $600 I think .Also found a bit of info about what works and what doesn't .
    Had a dig around egay also and found an ic for $320 so it mite get the nod.
    Craig
