Results 31 to 35 of 35
Thread: Still got a fwarkn SQUEAL ZD30 crd
  1. #31
    Mar 2013
    I have a loud squealing coming from the front of a 3ltr I got last wed, driving it home the noise was very concerning but the guy I got the truck off says it was just the fan belt... After doing some reading on the friday I decided to replace the belt along with the idler pulley assembly. Started truck up no noise for about 15 minutes then it started again, If I spray some belt grip on the belt noise goes away. but then returns either a few hours later or when I start it again. any advice or suggestions would be appreciated. Alternator is near new air con doesn't work but I can see the belt pulley turning. If I spray even the smallest about of lube or anything at the back of the fan so it blows over the belts and pulleys the sound goes away....I'm already regretting swapping my 4.2 for this truck...
    its either your alternator pulley ,tensioner pulley bearing. What brand belt did you fit Gates or OE would be the only choices
  4. #33
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Did you replace the belt with an oe
    my theory on this is the thickness and
    depth of the groves has some effect
    on the squeal
    other wise its an alternator or
    air con bearing
  5. The Following User Says Thank You to Sir Roofy For This Useful Post:
    BigRAWesty (20th December 2016)
  6. #34
    43 Post(s)
    Belt grip was probably not the best solution for a noisy belt..
    Try chalk.
    Try chalk.
    agree belt grip is a nasty product in some circumstances
  8. The Following User Says Thank You to threedogs For This Useful Post:
