Results 11 to 20 of 26
Thread: Are Beadlocks legal in Australia?
    Quote Originally Posted by Sir Roofy View Post
    Still illegal though. As you need to drill a hole in the rim. Which we can't do.
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    from what read there's only the one valve hole
    did click on the one you fancy there's a discripion
  4. #13
    80 Post(s)
    A lot of mucking around to fit the internal bead lock. https://www.youtube.com/watch?v=QJbAsemU6LU
  5. #14
    Yeah I read that, then they say this. The only modification required is the drilling of an additional hole in the rim. The system will fit one piece steel and alloy rims
  6. #15
    80 Post(s)
    http://www.secondair.com.au/howitworks.htm Secondair still requires a hole drilled. Edit, beat me to it.
  7. #16
    You snooze, you lose.
  8. #17
    TRAFALGAR VIC
    35 Post(s)
    must have missed that bit that's a different page to what I was looking at
    ah well Sh happens
  9. #18
    Hardcore
    central coast nsw
    Love the pic of the bloke standing between the recovery rope.
    it looks real safe.
    lucky he has gloves on, that'll save him.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  10. #19
    Jul 2015
    Camden NSW
    6 Post(s)
    Pretty sure the answer is no, most motor x bikes have them std
    Not sure about internal bead locks as well
    Internal bead locks were also common on many early British road bikes, before tubeless tyres.
  11. #20
    Dec 2017
    NE Melbourne
    Bit of an old thread but I was interested to read about the inflatable bead locks. I looked at the Staun inflatable bead locks a number of years ago for use on a vehicle being supplied to the Australian Army and even went as far as getting one of our rims drilled for a second valve hole and having a Staun bead lock fitted as a concept demonstrator but we didn't end up going ahead with them. I can remember at the time thinking that surely it wouldn't be that hard to come up with a bead lock that had a single valve that was able to somehow "telescope" in and out to allow you to fill either the bead lock or the main tyre from the same valve. A while ago I saw that this concept has been developed for mountain bikes to allow them to run tubeless setups and they have implemented a single valve that can inflate either chamber (albeit a presta valve and not a schraeder valve). https://www.schwalbe.com/en/procore.html
    Pretty nifty piece of German engineering and it had me thinking that surely this concept could be pretty easily applied to a Schraeder valve on a 4x4 tyre??
  12. The Following User Says Thank You to Big Gags For This Useful Post:
    mudnut (9th January 2018)
