Results 21 to 30 of 33
Thread: Hot box
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Go over the rocker cover bolts too. Just incase you hadn't thought of it....
    was there any post new motor routine to follow after the install.
    like re tighten head bolts or just a general check
    grab one of those ext dentist style mirror to see around the back of the motor
    Sir Roofy (30th November 2016)
  5. #23
    TRAFALGAR VIC
    35 Post(s)
    Ok had the mechanic look at truck with his cable
    camera and tells that a tube seal on number 4 injector
    is leaking he showed me and yep was oil there
    Not much oil has come out since I washed it down
    well after driving 200ks today the oil is down to add
    Are these seals hard to replace and would I need to
    replace the injector lines as well ? this is on a zd30 di motor
    Correction dipped the oil this morning was just below full
    mark
  6. #24
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by Sir Roofy View Post
    mark
    bumping hoping someone can give me an idea
  7. #25
    465 Post(s)
    mark
    Sorry mate was kinda busy yesterday.lol
    Anyhow. On each injector there is a oring that sits in a groove on the injector. The injector pushes into and long hole in the head. I cant see this beeing the issue as to my understanding this oring is there to stop the oil from getting down this tube and leaking into the cylinder.
    The injector itself sticks out the side of the head and there is a seal on this. This is what you mech is referring too. Pretty common for those seals to go.
    As for the repair side if it.
    The intercooler needs to come off. I dont think you would need to remove the intake manifold but it will be a tight spot to access the suspect seal. Undo the injector line from the injector, grab a long small flat head screw driver and lever out the old seal and then replace with the new.
    it will be a fidly job no doubt.
    Is the donk under any warranty still. Maybe even ring the bloke and talk to him about it.
  8. #26
    TRAFALGAR VIC
    35 Post(s)
    Thanks mate understand you're busy ok can see how the seal comes out
    does it just push back in ? or needs abit of effort to lock it in as there is a
    spring in it
    also I shouldn't need to replace the injector pipes ??
  9. #27
  10. #28
    TRAFALGAR VIC
    35 Post(s)
    Thanks TD I saw that before
  11. #29
    465 Post(s)
    spring in it
    These seals simply just push in. The spring in it is to just hold tight on the injector... You wont need to replace the pipes.
    Again I'm not sure, well I can't remember, if this can be done without removing the intake manifold. But I dont think so.
  12. #30
    TRAFALGAR VIC
    35 Post(s)
    sounds good so far might have to lift rocker cover though
    thanks
