Results 1 to 5 of 5
Thread: Something loose
    Oct 2016
    Sydney NSW
    Something loose
    Had a bad rattle under dash after a light off road trip, well today I found this thing loose lucky I found the nut and bolt and now it's tight again. Question is what is it? Also could this be the reason for my tacho jumping?
    465 Post(s)
    Going by the part number it seems to be a control module for the injectors. Whether this is linked to your issue? Not sure. Is your tacho jumping now?
    Oct 2016
    Sydney NSW
    Thx mud
    Went for a drive on smooth road and had hardly any rattle prior to finding it loose with no tacho problem but I know when I drive to work there are some rougher roads so hoping this may have been the problem, stay tuned.
  5. The Following User Says Thank You to Pj-14 For This Useful Post:
    mudski (29th November 2016)
    Oct 2016
    Sydney NSW
    Had a good day out to McMahons lookout in Wentworth Falls and then over the mountain to Wheeney Creek and not oncedid the tacho bounce nor the engine light come on so hopefuly mystery solved. Getting a full check up today and if all comes back good then upgrades will be coming.
  7. The Following 2 Users Say Thank You to Pj-14 For This Useful Post:
    mudnut (1st December 2016), mudski (1st December 2016)
  8. #5
    Good to hear you have found the culprit.
