Results 1 to 7 of 7
Thread: Oil Blow by from rocker cover gasket - How I fixed(RB30 Patrol)
    Legendary dom14's Avatar
    38 Post(s)
    Hey Guys,
    I used Permatex Ultra Grey. I ffilled the groove on the rocker cover edge with the sealant
    and squeezed in the rubber gasket. Then I also applied a layer of sealant on the cylinder head edge when rocker
    cover sits. I left it for about an hour to cure partially and get "tacky".
    Then I fitted it and left it for couple of days to cure properly before starting the engine.
    It's been more than a month and no more oil leaks from the rear end of the gasket.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. The Following User Says Thank You to dom14 For This Useful Post:
    mudnut (14th October 2016)
    80 Post(s)
    Too easy. It is a common problem on the dirty thirty.
    38 Post(s)
    Nah...it was never easy. Until I used Pertamtex Ultra Grey and did a thorough cleaning of the rocker cover edge groove, rubber gasket, cylinder head edges. It was left for two days to cure. That was the key.
    Cheetah Outreach
  6. The Following User Says Thank You to dom14 For This Useful Post:
    mudnut (15th October 2016)
  7. #4
    38 Post(s)
    I'm just adding another photo, explaining what did bit further & also added a link to fleabay Permatex Ultra Grey deal(a damn good deal), below.
    http://www.ebay.com.au/itm/2-TUBS-of-PERMATEX-ULTRA-GREY-ENGINE-GASKET-MAKER-RTV-SILICONE-99G-IN-EACH-TUB-/191785551094?hash=item2ca74f44f6:gMoAAOSwFqJWnJEq
    Years of intense suffering has come to end for me and the engine exterior from the blow-by oil leaks.
    It looks like it's holding up for good for long time.
    P.S. The rocker cover in the photo isn't mine. The "splash plate" is.
    Cheetah Outreach
  8. #5
    Caboolture, QLD
    RD28 with vacuum pump, engine settings
    Hi guys n gals, this is my problem with my 1998 RD28. Before I take the rocker cover off, does anyone know what the story is with the engine setting to put the cover back on? It has a 'vacuum pump?' on top.
  9. #6
    38 Post(s)
    Quote Originally Posted by Oversize View Post
    Open a new thread to discuss your issue. You get the attention that way.
    Cheetah Outreach
  10. #7
    Caboolture, QLD
    Thanks Dom14, Thought I would attract the attention of those in the know! Shall try a new post.
