Page 20 of 64 FirstFirst ... 10181920212230 ... LastLast
Results 191 to 200 of 634
Thread: Turbo Upgrades for the GUIV TD42Ti
  1. #191
    North brissy
    Do you just vent to atmosphere? At the moment it's returning into the intake.
    I removed the main section and blanked off what I could. The pipe from the turbo around the back of the motor is still connected but blanked the intake end as it was to hard to remove without messing with the turbo from memory (8 years ago) I will remove the lot this time around.
    I do.
    The EGR system has a cooler which cools the exhaust gas before entering the cooling system. Removing this cooler will take some load off your cooling system as well. The pipe around the back can be removed with the turbo in place its just a little tricky.
    As I have mentioned to you on the phone if someone has altered the static timing of your pump this wont be helping any of your causes.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    MudRunnerTD (22nd November 2016)
    330 Post(s)
    I do.
    Is that like a long Log style closed cooler like a water to air type log? Yes I have removed that assembly.
  5. #193
    330 Post(s)
    You can see my Oil drain slightly in one of those pics. However I am using the larger frame turbo than you guys and it all sits further forward. I just used the drain hose that was with the UFI 18G I had prior.
    So in the pic you can see the Water feed out the side of the block looping down then back up to the turbo yeah?
    The hose with the formed bend in the middle of the pic is the Oil line and just needs to be a suitable oil hose with hose clamps?
  6. #194
    583 Post(s)
    So in the pic you can see the Water feed out the side of the block looping down then back up to the turbo yeah? The hose with the formed bend in the middle of the pic is the Oil line and just needs to be a suitable oil hose with hose clamps? Sent from my iPhone using Tapatalk
    Yeah but you really want a nice flowing hose to your sump. You do not want any restriction here with twists or bends or restrictions otherwise you could end up like me potentially.
  7. The Following User Says Thank You to AB For This Useful Post:
  8. #195
    583 Post(s)
    Mine.......
    Too tight or not enough room for error to go above the oil drain line running the water feed with that system?
  9. #196
    North brissy
    I used heavy hose and it doesnt bend well. That hose is rated to over 5000psi
    Also using a bigger frame turbo which puts everything in different places.
  10. The Following User Says Thank You to nissannewby For This Useful Post:
  11. #197
    I paid a little less than that actually but hey are listed on eBay for $240 or more so figured it was a pretty good price to be honest?
    @mudski I understand that the fan should not be on all the time or it will affect fuel economy and engine load. I understood it would engage at a certain temp and pull the temp down before disengaging. Not necessarily to hold the temp lower but rather pull it down faster when it engages. The water pump on the other hand should hold the temp better I'd have thought for sure. That's the plan anyway.
    Yeah engine load and fuel eco is of some concern. The fan noise is worse though...lol. Yeah correct on how it works but the issue is the hub disengages too early. There for not pulling the temps down enough. So thats where the hub oil comes in. But i am thinking i might have a little too much oil now in mine. It still requires more than whats originally in there but i may have too much in mine i think. I have the same water pump too as you have bought....
  12. The Following User Says Thank You to mudski For This Useful Post:
  13. #198
    Patrol God Stropp's Avatar
    31 Post(s)
    Thanks for the info daz, that fan looks like the Ufi one
  14. #199
    Expert TheFlyingBadger's Avatar
    Oct 2010
    Perth
    I do.
    I used the water connections for that cooler for my Glind. nice tidy job (for once!).
    Jon
  15. The Following User Says Thank You to TheFlyingBadger For This Useful Post:
    MudRunnerTD (23rd November 2016)
  16. #200
    583 Post(s)
    Are we all set for the weekend Dazz?
    Looking forward to redlining a GU
  17. The Following 3 Users Say Thank You to AB For This Useful Post:
    MudRunnerTD (28th November 2016), Stropp (28th November 2016), Winnie (28th November 2016)
