Page 168 of 220 FirstFirst ... 68118158166167168169170178218 ... LastLast
Results 1,671 to 1,680 of 2192
Thread: AB's new GQ is finally here
  1. #1671
    583 Post(s)
    Disaster! Austpost have stuffed us around and the vac pump from Benny is still in transit!
    465 Post(s)
    No! Aus Post would never do that! Has the tracking number been checked in here in Melbourne at the sorting facility?
  4. #1673
    583 Post(s)
    No .....
  5. The Following User Says Thank You to AB For This Useful Post:
    MEGOMONSTER (28th October 2016)
  6. #1674
    If you call your local Australia Post and tell them you really need it they will open especially for you tomorrow! Your in the country and thats how they roll........ in 1973
  7. #1675
    583 Post(s)
    They're open tomoz mate but the status says it hasn't even hit Melb yet.
  8. #1676
    Bugger. i was taking the piss mate.
    see if it has a location in the morning and make a trip if you can? unlikely though.
    You will se it Monday though. are you taking Tuesday off mate
  9. #1677
    583 Post(s)
    Bugger. i was taking the piss mate. see if it has a location in the morning and make a trip if you can? unlikely though. You will se it Monday though. are you taking Tuesday off mate
    Yeah fingers crossed for Tuesday start up...
  10. The Following User Says Thank You to AB For This Useful Post:
    Chappy (28th October 2016)
  11. #1678
    193 Post(s)
    Oh bugger that's a pain. What other bits do you have to put on before it's time to drop it in?
  12. #1679
    583 Post(s)
    Still in transit this morning, bugger!!!
    I just need to get the clutch and flywheel on.
    Injector pump and lines
    Vac pump
    I think thats it...
  13. #1680
    583 Post(s)
    Does anyone know the difficulty of putting the vac pump on whilst engine is in?
    Should I just get this engine in so I can spend the weekend hooking everything up and then just put the vac pump on when it turns up?
    It sits below the injector pump so I'm guessing access from underneath would be best?
    Nightmare job or doable???
