20th October 2016, 09:52 AM
Setting up a viscous fan
So I'm about to order a new viscous fan hub as mine is screeching. I've decided to just get a new one instead of trying to refill the old.
What is the process for adding fluid? I've read where people have used a trial-and-error method of adding and testing to make the fan work at the right times but surely I can just put a set amount in and forget about it?
TB42s auto.
>>>tappin from tassie
Hello from Under Down Under!
20th October 2016 09:52 AM
20th October 2016, 10:38 AM
The 747
You have to pull it apart to put fluid in it. I think only the TD42 ones can be refilled?
A new one should come with the correct amount of fluid in it.
The Following User Says Thank You to Winnie For This Useful Post:
taslucas (20th October 2016)
20th October 2016, 11:55 AM
Ahhhhh right awesome. The thread I was reading was about an rd28 and I assumed they were the same. Sweet
>>>tappin from tassie
20th October 2016, 12:32 PM
You can fill the TB hubs but you need to drill a hole in it, put the oil in and then cap the hole off. Pretty sure I seen it done ages ago on the other forum.
The Following 2 Users Say Thank You to mudski For This Useful Post:
dom14 (22nd October 2016), taslucas (20th October 2016)
20th October 2016, 03:12 PM
Rotaredom
Twin thermo's.............. they don't need oil *L*
20th October 2016, 03:48 PM
NissanGQ4.2
Your patrol doesn't even need wheels at the moment!
Harsh
>>>tappin from tassie
20th October 2016, 04:46 PM
Rotaredom
taslucas
Harsh
>>>tappin from tassie
If it didn't have wheels I wouldn't be able 2 move it 2 get the camping trailer out!
It needs its wheels *L*
