1st October 2016, 07:21 PM
Intro from Xxn480 new ZD30 owner with issues
Introduction,, Darren Saying hello to all. New ee with prob, bahahaaaaaaaaaa. 02 gu driver. Engine temp high , only from 3,000 rpm & up. Below 3,000rpm spot on. Zd 30 donk . 391,000 km's . Be nice, lol. Any idea's may help. Thank you.
1st October 2016 07:21 PM
1st October 2016, 08:42 PM
@Doggy @AB @MudRunnerTD @Clunk this bloke needs help Mods....
The Following User Says Thank You to Avo For This Useful Post:
MudRunnerTD (1st October 2016)
1st October 2016, 09:04 PM
Nasty Dog - Moderator
Just moved your post to here mate, hopefully someone may be able to assist you......................me, I have no idea
If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
1st October 2016, 09:24 PM
I am he, fear me
400K on the cooling system means I would be giving it (ccoling) a complete overhaul.
Bottom of the rad core is probably blocked with goo inside and mud/crap/bug guts in the fins for starters
2nd October 2016, 08:38 AM
Doggy
Thanks bloke, fingers crossed.
2nd October 2016, 08:59 AM
Radiator new 30,000 km's ago. Have gone through basic checks. Flushed cooling system, both fans seem fine. Replaced thermostat.i was thinking maybe egr , so I just fitted Dawes valve & needle valve system. Part of Nads mods. Has made a huge difference. But didn't help with over heating. Exhaust temp only around 300 degrees, water temp up on boiling. Starting to think about turbo maybe? Not sure what I have missed. Any thoughts much appreciated. Thanks.
2nd October 2016, 09:27 AM
Moderator
Have you had a compression test? How is the boost holding? Any oil in the water? I'm thinking Haed to be honest. Would be great to find it's the head before it goes bang mate.
Check out my Toy -->
Rogue Dung Beetle
2nd October 2016, 09:43 AM
No oil or bubbles in water. Was thinking that way to start with. Still not sure. Boost slightly spikes & then holds fine. Not sure if I have Dawes valve tuned correctly yet, just fitted it. Thought it might have to do with slight spike. Boost gauge fluctuating between 0&1psi at idle ? Cheers.
2nd October 2016, 10:42 AM
Are you using factory or after market temp gauge? Big difference on result.
2nd October 2016, 01:09 PM
I am he, fear me
Xxn480
Fair enuf, that extra info helps.
Are any of the symptoms different now to what it was doing 30K ago before you changed things IE did it improve at all or make it worse or stay the same?
How long have you had the vehicle?
Did the issue come on fairly quickly?
The engine fan should be roaring and pulling a shitload of air when fully clutched, if it isn't the fan clutch is shot
Reasons I ask are;
After that sort of maintenance the system may need 'burping' IE air pockets in the system.
Did you correctly check the fan thermo clutch? I would service the clutch and replace the fluid anyway (use Toyota fluid).
The eleccy thermo fan (A/C) usually won't do squat at high revs so you can pretty much ignore that other than making sure it switches on at hi engine temp.
When the engine was flushed was it a full on pressure back flush or a garden hose jobbie?
Blocking EGR won't usually do squat for high revs as the EGR valve is mostly closed then anyway
EGR is only open at lower loads/idling to lower NOX pollution emmissions
I would also do a leak downtest as MRTD suggested, just for peace of mind if nothiing else
