Results 11 to 20 of 36
Thread: AC Bearing
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by Roosim View Post
    Thanks for all the info, most appreciated. It is the internal compressor bearings - booked in with the mechanic on Friday.
    Thanks Westy - will get back to you once we know.
    $900 for the internal bearing sounds way too dear. I would've imagined you can get a brand new compressor for that price.
    Then you still have to get the system flushed, lubricated and regassed at an A/C shop.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Expert johno90's Avatar
    Moranbah QLD
    You can get them for that price haha, if we are talking about the bearing behind the clutch then its an easy job all you need is a puller and a press make its easier. or a good hammer. Use the puller to pull the clutch off the front, undo the circlip then pull off the pulley, then press bearing out of pulley go to bearing shop and purchase then reverse install Should be $50 max
  4. The Following User Says Thank You to johno90 For This Useful Post:
    OuchOne (20th May 2022)
  5. #13
    43 Post(s)
    My clutch bearing was $65.
    But the actual pump which is being replaced is about $1000.
    Genuine is about $1600
  6. The Following User Says Thank You to BigRAWesty For This Useful Post:
    dom14 (15th September 2016)
  7. #14
    Moranbah QLD
    I can supply brand new compressors for around $800 mark some cheaper depending what model
  8. The Following User Says Thank You to johno90 For This Useful Post:
  9. #15
    38 Post(s)
    Quote Originally Posted by johno90 View Post
    It's the internal bearing of the A/C pump, by the sound of it. Bearing behind the clutch shouldn't cost anywhere near $900.
    I got the bearing for around $30 from Bearing Wholesalers.
    Cheetah Outreach
  10. #16
    Moranbah QLD
    I doubt its the internal bearing as he said it only failed after a muddy and watery trip. Id say he was quoted $900 all up including labor which is nuts but same like to charge haha
  11. The Following 2 Users Say Thank You to johno90 For This Useful Post:
    dom14 (15th September 2016), jay see (15th September 2016)
  12. #17
    38 Post(s)
    Hmmmmm........$900 to replace the A/C clutch bearing sounds like a highway robbery to me.
    Cheetah Outreach
  13. #18
    49 Post(s)
    That's how my one died.
    I don't think the $900 quote is to replace a clutch bearing. Well I hope not.
    @Roosim please confirm what your been quoted for.
    Sent from my XT1068 using Tapatalk
  14. #19
    465 Post(s)
    Thats how they all die. I replaced the idler bearing twice i think it was.
    Kallen needs to fab up a shroud for them.
  15. #20
    38 Post(s)
    I hope not as well. Recharge is usually around $200 depending on the place and what else needed to be done.
    Replacing clutch bearing wasn't that hard(at least in my RB30).
    Cheetah Outreach
