Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 56
Thread: What did you make today ?
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    I used my old KAB 403 suspension seat for my mancave
    Sheesh I thought mine was flash especially the RMW one !
    Macca
    I think the original cost was something like $1600 plus fitting.
    OK in Back hoe no place in a 4x4 lol.
    Ill grab a pic tomorrow weather permitting
  4. #13
    OK one of my sons working in Traffic found a 42" lightbar on the freeway.
    the lead has been cut and it slid a fair distance looking at it. Any way it has no mounting bolts
    so I unscrewed the end caps to have a look [easy as I think] so I tack welded a penny washer
    to a 6mm bolt and cut flats on the washer to suit the end caps.
    Now its stronger than before, well I think anyway
  5. The Following User Says Thank You to threedogs For This Useful Post:
    Stropp (4th October 2016)
  6. #14
    Repaired the other end the same way,,,,, now I have a 42" lightbar with spread on each end
    Not sure where to mount it if at all, Better check to see if it works first eh lol
  7. #15
    Here it is ,,it was up high like a stool, but one of my sons have cut it down
    Much better down low infront of the fire IMO lol
    Noticed he's made another from the front seat of a holden.
  8. #16
    22 Post(s)
    Been knocking up an adjustable spreader bar for engines. Still need to sort out lifting attachments
    96 GQ coil/Cab
    08 G6eT
  9. The Following 3 Users Say Thank You to Ben-e-boy For This Useful Post:
    Kimbo63 (1st October 2016), Stropp (4th October 2016), threedogs (21st December 2016)
  10. #17
    I may have put this here before, but if you have 2 horse shoes and a rail peg
    you can make you're own rustic stubbie holder, you can even put a lower shelf on it
    to hold your smokes etc. 12mm rod would be better than what I have but you
    get the picture, lol
    @ben e boy could you use eye bolts as a lifting spot
  11. #18
    Ballarat, Vic
    174 Post(s)
    Thought I might post a few pics of some of the stuff I’ve been building in our shed. Keeps me busy, gives me a reason to get up each morning, & is taking us ever closer to our dream of long term travel.
    The shed (& the wood store built from old hardwood pallets)
    Dwelling layout
    The workspace & the dwelling exterior
    Cupboards
    Wardrobe -4 bays/doors 3.8 metres long
    Kitchen
    Living room
    Mobile cabinet for a benchtop oven & microwave. (rather than take up valuable bench & cupboard space in the kitchen this will live in the shed & get wheeled in & out as needed - or just used in the shed).
    Bathroom
    Used ‘Signbond’ (3mm powder coated aluminium sandwich panel for shower walls & splash back )
    I’m slow as I need to learn many things as I do them, but I’m getting there. Have been refurbishing some secondhand doors today, & expect to be laying vinyl flooring (planks) next.
  12. The Following 5 Users Say Thank You to Cuppa For This Useful Post:
    Avo (22nd December 2016), BigRAWesty (21st December 2016), taslucas (22nd December 2016), threedogs (22nd December 2016), Touses (22nd December 2016)
  13. #19
    Awesome work Cuppa. How much of it have you done yourself?
  14. #20
    Ballarat, Vic
    174 Post(s)
    Ta. Neighbour is a sparkie & helped with the wiring. Paid a plasterer to do the gyprock & a plumber to install the gas (for compliance certificate), but basically everything else I've done myself (with occasional help from MrsTea).
  15. The Following User Says Thank You to Cuppa For This Useful Post:
