Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: after market temp guage y61 4.2td
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Thread bump 4 4bee as his post went into moderation
    @macca
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Quote Originally Posted by 4Bee View Post
    Hi Macca . . . waaaaayyyyy old thread, but if you can cast your mind back, was the Speedflow adaptor you bought a 12mm 1.25 pitch to go into that hole on the thermostat housing? or did you have to drill and tap it?
    Thanks mate
    Simon
    Sorry mate just got the notification to let me know there had been a quoted reply.
    As for your question I have no idea, unfortunately the part that came out is buried in the Trol ready for an extended trip. Carry it as a repair if the sender fails / leaks.
    Think @Cuppa did something like this so he might be able to help.
    Macca
  4. #13
    Ballarat, Vic
    174 Post(s)
    Hi, yes I copied Macca with the Speedflow adaptor. It screwed straight in with no need for any drilling & tapping. Easy & convenient. It was 12.mm x 1.5 pitch. See pic below for part no. In normal use my coolant temp reads 80 degrees, rising to 90 degrees in hotter weather & under load.
  5. The Following User Says Thank You to Cuppa For This Useful Post:
    dom14 (13th July 2016)
  6. #14
    Jun 2016
    Brisbane
    Thanks Macca & Cuppa,
    I did eventually get one of those same adaptors, but had to run a tap through the hole to get it to screw in . . .
    All good though, its working like a champion now
    I see my previous post went into moderation? what's that all about?
    thanks again
    Simon
  7. #15
    Expert Rip'n'Shred's Avatar
    Hunter Valley, NSW
    Cuppa, is that adaptor with the redarc 1/8" temperature sender? Fit ok? Does the probe stick out of adaptor far enough to reach coolant?
    GU IV 2006 4.2 TDi wagon
  8. #16
    Ballarat, Vic
    174 Post(s)
    Quote Originally Posted by Rip'n'Shred View Post
    Hi Rip, Yes it's with the redarc sender. Fitted & works perfectly.
  9. The Following User Says Thank You to Cuppa For This Useful Post:
    Rip'n'Shred (3rd September 2016)
