Results 21 to 30 of 35
Thread: list of items I am looking for suit GU 2001...
  1. #21
    Quote Originally Posted by Dan02 View Post
    RE: - bull bar, found the MCC rocker has mount points on the front for d shackles , looks great but am a bit dubious
    thanks have reloaded images
    They would be just for somewhere to hang your winch hook from, or a tie down point say if your on a tow truck...
    thanks Mudski
    I sent the entire list off to Vic and QLD specialist wreckers for a start, can I say parts are getting harder and harder to find, only got a couple back thus far. The factory steel bull bar is a bit of myth apparently, no one has one ATM. or there not letting on lol. so far the only thing I scored used is the overhead compass ( which I have been told is a headache)
    Niss4x4 in Brooklyn will have pretty much everything I reckon, but, you need to ignore their attitude. Its worse than my teenage daughters....
    no worries I also picked up the tow hitch block that suits a D shackle from Dobinsons, please tell me that this is the correct recover point
    Thats usually the best spot...
    Expert Dan02's Avatar
    Apr 2016
    Petre, Bris, QLD
    Have you started a build thread yet??
    Have PM you
    cheers
    2001 Patrol 4.2TD manual 2" lift; Beaudesert 3" Exhaust
  4. #23
    Apr 2016
    Petre, Bris, QLD
    have been in contact with Nissan 4X4 over the past week, its been a bit of a struggle, have ordered the dual battery setup and compass thus far, whats with those folks anyway lol, I actually do want to buy stuff but its like you say,,, a little difficult. Am at the point of giving up on them actually but really want that compass
  5. #24
    snip...
    With the LSD when one wheel loses traction do you just pull a bit on the handbrake to lock them both? I've never tried it but read / heard a few times thats the trick,
    Pulling on the handbrake won't do squat in a GQ/GU Patrol as the Handbrake Drum is on the Transmission Shaft not the rear wheel drum/caliper.
    If you have a vehicle that has a handbrake that actuates the rear brakes then, yes, that tip does work quite well.
    mudski (6th August 2016)
  7. #25
    Apr 2016
    Petre, Bris, QLD
    so much for that lol...
  8. #26
    No biggee... as prev mentioned by others the Nissan LSD is the best in the business and you can shim it even tighter if you want too but short of comp or really gnarly stuff there isn't any need IMHO
  9. The Following User Says Thank You to the evil twin For This Useful Post:
    Dan02 (6th August 2016)
  10. #27
    @Dan02 PM sent I have contacts in Brendale
    Also if you lift a front wheel going up some ruts you can tap the brake
    to stop the air bourne wheel spinning and give drive to the wheel on the ground
    I dont use that lock up box any more,,,Ive made a faux wheel that goes there
    and mounted my spare on the inside
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #28
    Apr 2016
    Petre, Bris, QLD
    QUOTE:I dont use that lock up box any more,,,Ive made a faux wheel that goes there
    and mounted my spare on the inside[/QUOTE]
    mate that is a great idea for the back door spare, have PM re this
  13. #29
    Post would be in the $35 dollar to maybe $45 dollars
    from Melb to Bris.
  14. #30
    Apr 2016
    Petre, Bris, QLD
    what about all the other gear?
