Anyone got pics of how their mechanical fuel pumps are setup on dual fuel? My Gq hasn't been running on petrol for awhile and I'm looking to get it running on it.
The inlet and outlet hoses on my fuel pump were just plumbed together with a single hose, and the return hose (from fuel pump) is hooked up to the return fuel line to the fuel tank (which should be right I think).
There is a hose coming from my supply fuel line to my fuel filter, then to the back of the little gold flow box (pictured in the 2ndrd pic on the left), then from that to the lock off valve, then to the carby.
What needs to be done to the inlet and outlet on the fuel pump? Getting abit confused trying to figure it out. Cheers!
Hopefully someone will be along soon to help. I'll try to get a photo if it's not dark when I get home. BUT...be prepared for a lot of carby issues as they don't like being run on straight gas for long periods of time and if the pump has been disabled on purpose then it's likely there's other issues.
>>>tappin from tassie
Thanks matey, yeah I am prepared lol, when I got it, it looked like someone had pulled mechanical pump off, refit it really dodgily lol it was just a mess, and just put random hoses on it, so I've put new hoses on it, new fuel filter and got another fuel pump In good order that was recently being used.
I noticed the petrol tank is ceompletely dry so I'm going to pull her out and give it a clean out first.
Oh, yes. You're gonna have lot of fun with lowering the petrol tank, which is more than likely a custom made tank.
Make sure to check to see if there's strainer in the tank pickup, and if not, install a one.
In the first picture on left side, I'm seeing an aftermarket electric fuel pump, so it looks like the mechanical pump has been plugged up for a good reason.
In the second picture, I can see a hose coming out of the mechanical pump, but also can see hose connected between two ends of the pump, so I'm not sure what's that about.
From the first picture, it looks like the aftermarket pump is the one that's connected to the supply line.
Thanks for your reply Dom, what do you mean I will have a problem lowering the tank? I could have it out in 5 minutes. And no it's not custom, it's factory.
I only realized the other night that the little gold box with flow on it is actually an electric fuel pump, hence why I've been so confused haha
I purchased the same pump for mine to install a redundant pump for mine, 'cos my existing pump is an old intank and it can die anytime.
No dramas if yours is the factory tank, so you should be able to access it from inside the vehicle using the factory access hole, right above the sender unit of the tank. Aftermarket tanks are PITA to deal with 'cos they are usually bigger, heavier and tight fits. I don't think you have to lower the tank, unless for some reason there's no access hole from inside of the vehicle, which is not likely. If the access hole doesn't line up with the tank sender, then factory tank has been moved or it is not a factory tank.
I should add below to clarify the above.
Aftermarket tanks don't align with the factory access hole. So, lowering them or dropping them is necessary to access the sender unit/intank pump.
