27th August 2015, 10:29 AM
#71
Daily Lurker
liftlid
Is there a vendor on the forum that sells these?
hey gary, how did you go with it mate? i couldnt get it off anyone on the forum i ended up going a random site.
27th August 2015 10:29 AM
27th August 2015, 01:17 PM
#72
rusty_nail
Haven't got one yet
1st August 2016, 07:56 AM
#73
I still have some questions on this old thread!
I picked up a dizzy with the igniter 2 (hall effect) from the scrappy. Looks ok and I want to do a straight swap with the original dizzy. I'm assuming I can leave original coil and ballast resistor with all wires still intact - right?
If all is well I will buy the flamethrower coil next. In that case I need to remove ballast resistor and tape up the 2 wires - right?
1st August 2016, 01:16 PM
#74
Yep spot on mate. You can retain the original coil as it is only "recommended" to upgrade the coil. Then later you can put the flame thrower is as you've described.
>>>tappin from tassie
Hello from Under Down Under!
The Following User Says Thank You to taslucas For This Useful Post:
amm009uk (1st August 2016)
1st August 2016, 01:17 PM
#75
Keep an eye on your tacho as any problems with the pertronix or coil will show up as a flickering tacho needle.
>>>tappin from tassie
1st August 2016, 03:27 PM
#76
amm009uk
I bought a Flamethrower and couldn't make it work. Got a mechanic to tune it after that and he said throw the new one away and keep using the original Bosch one. He reckons they're the only ones worth having.
1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
The Following User Says Thank You to ripper For This Useful Post:
1st August 2016, 03:55 PM
#77
My flamethrower has been installed and working for years now. You can damage them though. A mate with the same set up did the old 180 out trick and hurt his flame thrower coil so that it would miss but only under load.
>>>tappin from tassie
1st August 2016, 09:18 PM
#78
Thanks guys much appreciated
7th July 2021, 08:43 PM
#79
sorry to drag up an old thread. I have installed a pertronix Hall effect and now I want to install a gt40 coil and bypass the ballast resistor.
Im just wondering what cables go where on the coil from the resistor?
I have attached a picture of my old coil.
The Following User Says Thank You to Callum87 For This Useful Post:
7th July 2021, 09:05 PM
#80
Probably no help mate but back in a similar vintage petroleum pimping FJ40/45 days found fancy red gt40 coils problematic in the cold IIRC and reverted back to OEM + bog stock resistors…unsure memory
