11th November 2012, 10:14 AM
#21
I took note of the work done to ad another plate, that got me thinking of doing the same thing, the same way.
I have a couple of questions.
Who can i get them from off here and how much, you can PM me if you wish.
Second question is this.
Has any one adapted the plates together, by that i mean a cross member from 1 plate to the other using the existing unused holes in the plates ?
I intend to machine a bar of 50 mm dia with tapped holes in the ends to slip in between the plates to remove any independent side action when both are used together as one ?
Any feed back on the idea will help.
11th November 2012 10:14 AM
11th November 2012, 11:02 AM
#22
optic
Threedogs is the man to speak to. He makes the originals and would probably be able to answer any questions you have re fitment options.
11th November 2012, 07:54 PM
#23
Just send a PM , SORT IT OUT QUICK ENOUGH
11th November 2012, 07:56 PM
#24
Threedogs is the man for recovery plates. Also I can't see how your idea would work or be better than having just recovery plates. Seem a lot of work for something that will be no more efficient than two plates...Just a thought.
Edit :beaten by the man himself. Also upon re-reading your post I think i get the concept. Seem logical but using a bridle strap should take out any sideways movement in a snatch. Unless your getting snatched out on an angle.
11th November 2012, 09:14 PM
#25
Don't try and over complimpate a proven system . this is KISS .like I said just PM or pop over, easy to sort out, easier the better IMO
20th November 2012, 02:40 AM
#26
optic
I see your point but I'm pretty sure the points of which TD's recovery points attach to is not far from a factory cross rail. Given that and that you usually have a bull bar fitted up front to hold chassis apart I think a spreader bar across the chassis would be pointless.
And a waste of money.
Owner of
Westy's Accessories
27th July 2016, 04:46 PM
#27
Fixed the original posts as the pics somehow disappeared....
threedogs (27th July 2016)
11th February 2019, 04:27 PM
#28
Breadmaker Shaker
mudski
Thanks for this helpful thread Marko. Looks like this is what I'll need to do with my GUII.
![](image.php?s=8b21e1f5ea0c79f82de1e2061ccdc97a&u=115&type=sigpic&dateline=1651651487)
The Following User Says Thank You to Plasnart For This Useful Post:
mudski (11th February 2019)
16th April 2019, 08:35 PM
#29
Plasnart
Thanks again @
mudski, did this on mine today.
No problem mate. Glad this old thread is still helping others...
17th April 2019, 05:05 PM
#30
mudski
Are these your Threedogs? My missus wont say where she bought them from but I saw pics of yours and they look the same...
Yes they are mine probably from TJM Coburg
You can now buy the plate with captive nuts on it
left hand side on all GQs and series 1 GU is a bit fiddly
they are very strong when boltrd as @mudski did.
You can also bolt one of thost 10,000lb hooks to it.
Use the black ones the chrome tend to break
