16th July 2016, 06:32 PM
#2841
threedogs
what size panel I have a spare 80 watt here I may do similar with lol ??
I have a 160w foldable mounted on rhino roof racks and removable.
16th July 2016 06:32 PM
16th July 2016, 06:36 PM
#2842
Now would you run this to your AUX battery or have it switchable so the start can get some love as well
@sooty_10
16th July 2016, 06:38 PM
#2843
if your gonna go a 4" snorkel I wouldn't try and fit the factory one before hand, the holes needed probably won't quite line up with your 4" one and then you'll have extra holes to patch in your guard.
16th July 2016, 07:09 PM
#2844
I am he, fear me
threedogs
Up under the front deflector is that too far away from the battery for you ???
If you need to weather proof it whip done to Safeways and grab a tupperware
dish to suit.
I wouldn't put it on the roof anywhere, MPPT should as close to the Aux Battery as practicable
16th July 2016, 09:37 PM
#2845
gubigfish
That's exactly my hesitation until I decide which way i'm going.
16th July 2016, 09:38 PM
#2846
threedogs
sooty_10
I currently have a piranha dbs which has no interconnect or dual sense. Also contemplating down the track upgrading to the redarc sbi212d dual sense one. Currently looking at hooking only through aux.
16th July 2016, 09:39 PM
#2847
the evil twin
Yeah not going roof mount for it. Either under bonnet/behind dash or in rear on cargo barrier.
17th July 2016, 11:53 AM
#2848
sooty_10
Yeah I was led to believe the closer to the battery the better, how about in
the foot well on the left hand kick panel. Its only a short run to the Aux battery from there.
17th July 2016, 02:15 PM
#2849
threedogs
Yeah one of my contemplated options. I might even add a fusebox / junction in behind there somewhere.
18th July 2016, 04:10 PM
#2850
Some high pressure braided hose arrived , I also have some quick connect fittings to suit.
This will join some air tanks I have on the cargo barrier, hopefully This will help it look neat.
http://www.ebay.com.au/itm/291816824...%3AMEBIDX%3AIT
http://www.ebay.com.au/itm/251948189...%3AMEBIDX%3AIT
