Results 11 to 20 of 33
Thread: Auto TRANS won't drive
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Yeah me either Mark , when I changed the auto fluid last weekend I pulled the sump / pan thingy off for a look & you can't see bugger all , there's a big plate there with lots of wires and plugs and not much else, I guess the real workings are up inside it. I didn't know what to expect but I thought I'd see more than that ha ha
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Yeah I'll be on the phone in the morning Jay see 😩
  4. #13
    465 Post(s)
    You can't get an air lock in the auto fluid can you?
  5. #14
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    If any of the clutch packs were worn to the point of allowing excessive piston travel, the slip in your shift changes would have been quite noticeable and there would have been a lot of debris in the pan and on the magnet - unless you recently purchased it and the fluid change was done beforehand.
    As suggested, a pressure test would be a good idea but you'll find most shops will want to overhaul it.
    If you're reasonably mechanically capable, doing a rebuild yourself is possible with the factory manual.
    John
  6. #15
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Sorta like this Adam?
    Could really be anything, worn clutch packs, broken wire, damaged seal.... when my auto died in the GQ it was pretty much everything
  7. #16
    Jul 2016
    Agree with the sloppy shifts when the clutches are worn, but I guess it's something that may not be so noticeable to a lot of people as it has slowly worn over time.
  8. #17
    Jun 2015
    Heyfield Vic
    35 Post(s)
    yeah that's what I was faced with mate ! I've had 18 Spd truck gearboxes apart before & can understand ( to a point ) how they work but there wasn't much to see in here
    yeah I'm not confident it'll be a simple fix
  9. #18
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Quote Originally Posted by drz400y View Post
    I took it up the snow the weekend before & flogged the arse off it & it was fine , it was totally outa the blue . Got me fucked . I'll ring wholesale automatic transmissions on Monday when they open - they're supposed to be the gurus .
  10. #19
    Aug 2010
    17 Post(s)
    yeah I'm not confident it'll be a simple fix 😩
    If your handy on the tools Adam, as John said a rebuild is possible, you just need the time, tools and space..... none of which I really had. Do you know what model gearbox is in yours?
    http://www.nissanpatrol.com.au/forum...earbox-Rebuild
  11. #20
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Well mate I have the time now because I drive a log truck and we just finished last week due to the snow but its six of one - half a dozen of the other, I could take a week to rebuild it myself or I could go and do other work for that week and pay someone to do it , hopefully i'll know more Monday morning when I talk to the auto specialists and get some direction, rebuild cost or change over box etc to see what's better , it's like with truck diffs , you can take two days and rebuild it yourself but you lose two days of work so change over is better in the Long run, might be the same option here. Still up in the air as it wasn't part of my plan for this week ha ha
  12. The Following 2 Users Say Thank You to Sprock For This Useful Post:
    jay see (3rd July 2016), NissanGQ4.2 (3rd July 2016)
