Results 1 to 10 of 15
Thread: 2012 long range sub tank best option
    Expert rusty00's Avatar
    Jun 2015
    South Eastern VIC
    Want to replace the sub tank with a long range /larger tank, what is the best one to get and how much do they hold.
    Is it best to replace rear or sub tank and for what reasons is one better than the other.
    I only need an extra 30 to 40lt for what I do and can carry a Jerry or 2 if needed for remote trips like the simo.
    2012 GU8
    Not a biggee but IMHO the main is easier than the sub.
    No extra fuel to transfer or cannot use if you can't
    No issues with suspension arm clearance
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    rusty00 (18th June 2016)
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    depends on if your towing or not I think
    if you dont tow a van or camper - replace the main as ET said - easier to do
    if you are towing all the time - I suggest the sub - as it is in the middle of the car balanced weight- not adding so much weight to the rear where you have a Van attached
  6. The Following User Says Thank You to Bigcol For This Useful Post:
    rusty00 (19th June 2016)
  7. #4
    43 Post(s)
    Imo much of a muchness..
    The sub takes you from 30L up to 75L (usable fuel)
    The rear main goes from 90 up to 140 (from memory).
    Both or over $1000.
    The rear is slightly easier to install but adds more weight behind the axle..
    Imo I've done my main tank breather mod. So I have about 115L usable fuel there..
    Once I fit my 75L Lra sub I'll have 190L of usable fuel..
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
  9. #5
    I have a Brown Davis 75 ltr Aux tank and it cost me $750 new and fitted
    Gives me about 175 litres or a good 1200 range, taking it easy lol
  10. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    BigRAWesty (18th June 2016), rusty00 (19th June 2016)
  11. #6
    Jun 2015
    South Eastern VIC
    Lra look the goods, have asked them for a quote.
    I like the fact that they sit a bit higher than the Brown Davis units.
    Only want the sub replaced to gain an extra 40 odd litres.
    Both or over $1000.
    2012 GU8
  12. #7
    Advanced abw's Avatar
    Jul 2015
    Sydney, NSW
    I read somewhere some having problems with the LRA tank and the tailshaft hitting on full flex. Though this may only be a problem on higher lifts. I had a Brown Davis fitted. It's 75L. I'd have to say it's a tight squeeze..they use every square centimeter of space! It doesn't hang down any further than the muffler and the steel side step brackets.
    Andrew
    GU3 Patrol, TB48, 33" muddies. front E-locker. 4.11 diff gears. 2.2 metre steel rack. Awning. Steel rear bar. Safari Snorkel. ARB side steps and brush rails. ARB Deluxe bull bar. Winch. 2" lift.
  13. The Following 2 Users Say Thank You to abw For This Useful Post:
    BigRAWesty (19th June 2016), rusty00 (19th June 2016)
  14. #8
    43 Post(s)
    Quote Originally Posted by abw View Post
    Yea I have heard the same but yea on lift around the 4".
    Expert Boinzo's Avatar
    Dec 2015
    Brisbane
    I have a Brown Davis - recently fitted by TJM. Works great - holds 76L. Just happily took me over the Simmo.
    2015 GU ST 3.0CRD Auto Wagon, 2" EFS Lift, 5 x Procomp 16s with MT ATZ P3s, TJM Outback Bar and 12000lb Winch, 80l Sub Tank, Redarc 40A DC-DC with Optima Battery and 180w Solar, ARB Compressor On-board, 3" EXHAUST, Rhino Pioneer Platform and Darche Awning, DIY Drawers to come!
  16. The Following 3 Users Say Thank You to Boinzo For This Useful Post:
    BigRAWesty (20th June 2016), rusty00 (20th June 2016), threedogs (22nd June 2016)
  17. #10
    Jun 2015
    South Eastern VIC
    How many km did you do to fule usage.
    Quote Originally Posted by Boinzo View Post
    2012 GU8
