14th June 2016, 07:25 PM
slow / lack of power on uphill starts
Gday travellers,
My recent purchase of a GU 2006 Patrol, 4.8L auto has a little quirk.
I've noticed on a number of few occasions, usually when I've come to a stop, and then start to accelerate that the car is lacking power, I'm having to give it a fair amount of revs and even then its only crawling for 5-10 seconds until it starts to properly find 1st gear.
Anyone have any tips on what this is....
I'm thinking with it being an uphill thing it may be to do with fuel getting into the engine etc.....?
14th June 2016 07:25 PM
15th June 2016, 12:30 AM
Stop doing that and get it to a automatic specialist sounds like it is slipping in first or the fluid is low mine dose that when cold so I drive easy till it warms up the auto in a patrol needs to be service every 20,000 km
I never go into the outback with out a decent supply of water,
and the general rule for how much you'll need is three litres
per day , per person, per man per degree over 25 degrees
celcius, per kilometer if walking on foot, in the winter months
dividing it by two, plus... another litre... at the end .... Russell Coight
The Following User Says Thank You to Makka For This Useful Post:
BigRAWesty (15th June 2016)
20th June 2016, 02:17 PM
Makka
Gday Makka,
I reckon perhaps its not dropping back to 1st gear when I come to a stop?, its as if I'm moving off in 3rd or 4th gear, am booking it in.
Has only been happening occassionally, next time it does it I'll slip it into tiptronic - and see if that changes the occurence
3rd July 2016, 10:18 AM
Gav72
Gday Makka,
Hi People,
So I've tried moving from drive and dropping the tiptronic at what is coming up in 4th back to 1st, but I get no change in power.
Have checked the air flow sensor and it appears ok.
Have disconnected / reconnected the battery....
Problem still occurs, any ideas,
Can anyone else confirm if there at low speed and move over to tiptronic that it comes up in 4th?
any recommendations for a patrol specialist in Melbourne's eastern suburbs...
3rd July 2016, 10:20 PM
Any time you move the tiptronic lever over to manual mode it displays 4th. It doesnt mean though that it is actually in 4th from what I have felt in mine. However selecting 1st while your moving , like changing down as if was a normal manual should be able to be done.
I would be doing a flush on the box. See if that clears it up then go from there.
Other possible things wrong could be the torque converter being stuffed or slipping ratios internally. Will need an auto specialist to take a look and diagnose. Cant help with that sorry as im in WA
8th July 2016, 10:30 PM
Hiya,
So my service mechanic hooked up his little computer and found the following errors: DTC list - P1764: Direct Clutch Solenoid Valve / Circuit Fault. & P1845: Pressure switch 5 Circuit Valve Difference.....
He said its a bit hard to tell exactly, perhaps new oil/fluids??
I am taking it to a Transmission specialist next week.
Google machine has a few answers, anyone have a glaringly obvious answer to the above faults........
8th July 2016, 10:38 PM
hye mate duuno if they are the same...but i have a 2010 3ltr crd auto,and unless i come to a complete stop...the transmission will not go back to 1st,come up to a give way sign...no cars...take off but not stop...it is pittyfull....did ask someone about it and their answer was that they do not go back to 1st gear unless come to complete stop...
13th July 2016, 09:48 PM
#8
Hiya
So my Patrol has been in surgery. The transmissions guys have opened up and checked the solenoid valves and found no faults, diagnostics found no fault with the ecu either. They have cleaned the connectors/terminals? where there has been dust / carbon? dust or whatever and are hopeful that my issue may be fixed.
I'm off to pick up the Patrol from the mechanics tomorrow, expecting for what they have checked / tested will run into ...$4-500 or more??,
anyone have a feel for what I should be expecting to pay.....
14th July 2016, 12:55 PM
#9
OK
I have picked up the patrol today
The error codes for the transmission were P1764 & P1845
Mechanics did - scan test and check for code.
Perform solenoid actuations - No faults found.
Remove connectors & valvebody. Remove solenoids from heatplate. Heat up and check resistances. - ALL GOOD.
Clean all solenoid terminals and clean wiring connector.
Reassamble
No faults found / no solenoid failures
The Patrol has had the same issues - since I've driven it on the road today. ie: move off from a stop and car is slowww - like in 4th gear.
I turned off the engine and re started car - moved off and all good at normal speed (as suggested by mechanic).
Mechanic has suggested the next steps in fault finding this issue for permanent fix:
- 1. Check external wiring / harness - 1/2 days work......
- 2. work backwards from the transmission controller through the wiring and hopefully find fault.....
- 3. worst case scenario - Nissans suggestion - replace all wiring = $3-4k - which I hope it doesnt come to that....
Any suggestions gear heads....
14th July 2016, 02:05 PM
#10
Your snow mode switch is not on is it?
