Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: UHF Channel Cheat Sheet
    Others can't hear me.
    The volume is fine but transmission is all fuzz.
    The unit is a good quality uniden but the aerial was a cheapy with its cable hard wired. I reckon I should just buy a decent aerial.
    tappin from tassie
    If that is the case, me too
    Even an Oricom will sound OK on a good antenna...
  2. The Following User Says Thank You to the evil twin For This Useful Post:
    taslucas (11th September 2015)
  3. #22
    May 2016
    Lightbulb
    A long time ago, an old mate of mine put up this site and the info is correct. The PDF in the OP is not very accurate. I have brought it across and edited to be up to date.
    http://uhfcb.com.au/80-Channel-UHF-Information.php
    80 Channel UHF Information
    Channel: Frequency: Use: Channel Spacing:
    Channel 1 476.4250 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 2 476.4500 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 3 476.4750 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 4
    476.5000 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 5
    476.5250 Duplex - Repeater Output (Emergency use only) 12.5 KHz
    Channel 6 476.5500 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 7
    476.5750 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 8
    476.6000 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 9
    476.6250 Simplex 12.5 KHz
    Channel 10
    476.6500 Simplex 4WD Drivers - Convoy, Clubs & National Parks 12.5 KHz
    Channel 11
    476.6750 Simplex Call Channel
    12.5 KHz
    Channel 12
    476.7000 Simplex 12.5 KHz
    Channel 13
    476.7250 Simplex 12.5 KHz
    Channel 14
    476.7500 Simplex 12.5 KHz
    Channel 15
    476.7750 Simplex 12.5 KHz
    Channel 16
    476.8000 Simplex 12.5 KHz
    Channel 17
    476.8250 Simplex 12.5 KHz
    Channel 18
    476.8500 Simplex Caravan & Campers Convoy Channel 12.5 KHz
    Channel 19
    476.8750 Simplex 12.5 KHz
    Channel 20
    476.9000 Simplex 12.5 KHz
    Channel 21 476.9250 Simplex 12.5 KHz
    Channel 22
    476.9500 Data Only (No Voice - No Packet) 25 KHz
    Channel 23
    476.9750 Data Only (No Voice - No Packet) 25 KHz
    Channel 24
    477.0000 Simplex 12.5 KHz
    Channel 25
    477.0250 Simplex 12.5 KHz
    Channel 26 477.0500 Simplex 12.5 KHz
    Channel 27
    477.0750 Simplex 12.5 KHz
    Channel 28
    477.1000 Simplex 12.5 KHz
    Channel 29
    477.1250 Simplex Pacific Hwy (NSW) & Bruce Hwy (Qld) Road Channel
    12.5 KHz
    Channel 30
    477.1500 Simplex UHF CB Broadcasts
    12.5 KHz
    Channel 31
    477.1750 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 32
    477.2000 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 33
    477.2250 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 34
    477.2500 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 35
    477.2750 Repeater Input (Emergency Use Only) 12.5 KHz
    Channel 36
    477.3000 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 37
    477.3250 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 38
    477.3500 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 39
    477.3750 Simplex 12.5 KHz
    Channel 40
    477.4000 Simplex Highway Channel 12.5 KHz
    Channel 41 476.4375 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 42 476.4625 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 43 476.4875 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 44 476.5125 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 45 476.5375 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 46 476.5625 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 47 476.5875 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 48 476.6125 Duplex - Repeater Output (don't be a dick and TX on here) 12.5 KHz
    Channel 49 476.6375 Simplex 12.5 KHz
    Channel 50 476.6625 Simplex 12.5 KHz
    Channel 51 476.6875 Simplex 12.5 KHz
    Channel 52 476.7125 Simplex 12.5 KHz
    Channel 53 476.7375 Simplex 12.5 KHz
    Channel 54 476.7625 Simplex 12.5 KHz
    Channel 55 476.7875 Simplex 12.5 KHz
    Channel 56 476.8125 Simplex 12.5 KHz
    Channel 57 476.8375 Simplex 12.5 KHz
    Channel 58 476.8625 Simplex 12.5 KHz
    Channel 59 476.8875 Simplex 12.5 KHz
    Channel 60 476.9125 Simplex 12.5 KHz
    Channel 61 Reserved for Future Expansion
    Channel 62 Reserved for Future Expansion
    Channel 63 Reserved for Future Expansion
    Channel 64 477.0125 Simplex 12.5 KHz
    Channel 65 477.0375 Simplex 12.5 KHz
    Channel 66 477.0625 Simplex 12.5 KHz
    Channel 67 477.0875 Simplex 12.5 KHz
    Channel 68 477.1125 Simplex 12.5 KHz
    Channel 69 477.1375 Simplex 12.5 KHz
    Channel 70 477.1625 Simplex 12.5 KHz
    Channel 71 477.1875 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 72 477.2125 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 73 477.2375 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 74 477.2625 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 75 477.2875 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 76 477.3125 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 77 477.3375 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 78 477.3625 Repeater Input (don't be a dick and TX simplex on here) 12.5 KHz
    Channel 79 477.3875 Simplex 12.5 KHz
    Channel 80 477.4125 Simplex 12.5 KHz
    Licenses for Repeater Channels 44 & 45 will not be licensed for an additional 6 to 12 months to allow extra time for owners of Channel 5 Emergency repeaters to upgrade equipment to meet the new standards
    Channels 1 to 8 and 41 to 48 - Repeater Channels Press the DUPLEX button on your radio to used any available repeaters
    Channel 5 & 35 - Emergency use only - Monitored by Volunteers, No general conversations are to take place on this channel
    Channels 22 & 23 - Data transmissions only (Excluding Packet)
    Channels 31 to 38 and 71 to 78 - Repeater inputs - Do not use these channels for simplex transmissions as you will interfere with conversations on channels 1 to 8 and 41 to 48
    The Australian Government has legislated that channels 5 & 35 on the UHF CB Band are reserved for emergency use only
    As at January 2007 the maximum penalties for the misuse of the legally allocated CB emergency channels are:
    • For general misuse - if an individual 2 years imprisonment, otherwise $165,000 (a $220 on-the-spot fine can be issued in minor cases); or
    • For interference to an Emergency call - if an individual 5 years imprisonment, otherwise $550,000
    If you interfere with another persons conversation just select another channel and do not provoke troublemakers that may deliberately search out other people provoke a reaction, Just ignore them remember
    DON'T FEED THE TROLLS
  4. The Following 5 Users Say Thank You to LostBenji For This Useful Post:
    clawrence (21st May 2016), DX grunt (22nd May 2016), snicko (21st May 2016), sooty_10 (21st May 2016), the evil twin (21st May 2016)
  5. #23
    Mar 2015
    you have to feed the trolls LB ........ so they will come out from under there bridge and you can ...........
