Page 132 of 220 FirstFirst ... 3282122130131132133134142182 ... LastLast
Results 1,311 to 1,320 of 2192
Thread: AB's new GQ is finally here
  1. #1311
    193 Post(s)
    I was going to grab you tonight but it's shitty weather.
    Tomorrow 100% mate!
    Yeah sweet, just got home anyway ☺
    43 Post(s)
    Tomorrow 100% mate!
    While your out came take me for a spin...
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    AB (3rd June 2016)
  5. #1313
    North brissy
    I will just apologise in advance mate.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
    Rossco (3rd June 2016)
  7. #1314
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Here's some comments that I stole off someone who was there and has a lot of experience with our td42's.
    Fitting a special 12mm produced some very impressive boost response values. The only tune we did was to adjust boost to produce acceptable stable EGT's. We saw 15psi at 1400rpm, 25psi at 1700rpm, 32psi at 1950 rpm and 37psi in at 2100 rpm in a 4th gear pull. Combining these values with the comp map this turbo produces some 38 lbs/min before 1900rpm to produce I would expect a very impressive torque response curve. Until the clutch is fixed and flywheel lightened it is a bit pointless doing a dyno run to see how this turbo effects the torque curve and how torque could be effected by the small turbine above 3000rpm.
    Mate, unless your going to wind the boost back quite a bit it may pay you to have flywheel and clutch balanced.
    Pita whenever you need a new clutch as will have to rebalance but could well save you some grief/$ between times.
    With the sort of horses that engine will now produce a balanced shaft would have been nice too. After the fact now I s'pose.
  8. #1315
    582 Post(s)
    Yep I've put it back to 30, will get the flywheel lightened and balanced and pretty much get the heaviest exedy clutch.
  9. #1316
    North brissy
    Boost isnt the issue. Far from it really. I informed andy to knock the boost down to 32psi as running the turbo at 37+ means the shaft speed is getting up there. 32psi puts it in a safer area of its map while still retaining egt controllability.
  10. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    AB (4th June 2016), MudRunnerTD (4th June 2016), Winnie (4th June 2016)
  11. #1317
    Sounds like your pretty chuffed AB. You must take me for a spin one time.
    If only my car wasn't a daily i would be doing so much more to mine.
    Ill have to make a special trip up north one time and have Mat and Ben go nuts on it. Lol.
  12. The Following User Says Thank You to mudski For This Useful Post:
    AB (4th June 2016)
  13. #1318
    Feb 2014
    Caboolture
    I am glad you are having fun AB. You have a fun rig to drive which is what all this is about not those bragging KW numbers but drive ability in the extreme area. We expected this tiny hi tech turbo to be a good option for producing torque early. That it does very well. I asked Mat to get you to drop boost a bit I did some calc and wanted your rig to be well into safe mode until you get a better intake manifold. If you follow Mats lead here we can go nuts with boost and fuel adjustments on the Dyno up here when you visit September.
    With the flywheel a bit lighter we safe guard your crank so that's a must have. Balancing the wheel and clutch pack is more than enough to be well into the safety area.
    And I said 32psi not 30 psi BTW lol.
  14. The Following 5 Users Say Thank You to OldMav For This Useful Post:
    AB (4th June 2016), jack (4th June 2016), MudRunnerTD (4th June 2016), Rossco (4th June 2016), Winnie (4th June 2016)
  15. #1319
    582 Post(s)
    Quote Originally Posted by OldMav View Post
    I am glad you are having fun AB. You have a fun rig to drive which is what all this is about not those bragging KW numbers but drive ability in the extreme area. We expected this tiny hi tech turbo to be a good option for producing torque early. That it does very well. I asked Mat to get you to drop boost a bit I did some calc and wanted your rig to be well into safe mode until you get a better intake manifold. If you follow Mats lead here we can go nuts with boost and fuel adjustments on the Dyno up here when you visit September. With the flywheel a bit lighter we safe guard your crank so that's a must have. Balancing the wheel and clutch pack is more than enough to be well into the safety area. And I said 32psi not 30 psi BTW lol.
    Thanks for all your help mate. I need Rossco to help watch the gauge. It's pissing rain down here today and nearly killed myself testing it out...haha
    I'll get it to exactly 32 psi though
  16. #1320
    330 Post(s)
    Yeah the rain sux! Nuff'n to do with the rear wheels breaking traction at 25psi in 4th! Damn those wet roads!
    Vote 1 ARB Diff Lock ON in the back.... Line Locking in 4th at 25psi for the win!
  17. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    AB (4th June 2016)
