24th May 2016, 06:44 PM
#21
I am he, fear me
I would... and make sure the earths are in good nick
The Following 2 Users Say Thank You to the evil twin For This Useful Post:
Bigcol (29th May 2016), dom14 (24th May 2016)
24th May 2016 06:44 PM
#22
IMO a loom upgrade is a great mod, sealed beams are perfect if doing bog holes all the time .
but they are only GQ not GU
Jaysee has a GU so he needs to find a globe that suits his need.
Gu reflectors are only plastic.
Plus the higher you go [watts]the more chance you have they will blow from vibrations
John if you want to try some HID headlights Im sure to have a spare kit here.
24th May 2016, 10:35 PM
#23
dom14
Have you tried playing with the plugs/sockets to see if that's the culprit?
They are pretty cheap to replace. I even have a few spare ones at home that I ordered from China for few peanuts.
They are good quality. Just cheap 'cos it came from china.
If you want them, let me know via a PM.
If I'm going to replace plugs I get the ebay kit and change the whole lot. Thanks for the offer tho.
the evil twin
Don't fit high wattage globes (100/90 etc) to the standard loom.
They pull twice the current and will give your stalk switch a hard time.
I use Narva +100 in the standard wattage and they are pretty good.
Having said that, a loom upgrade and relays is a really good idea and cheap
If I'm going to run 100/90 I'll be doing the upgrade kit.
threedogs
Thanks mate, but I think I'll go the ebay kit or a something like what ET is using.
30th May 2016, 08:15 PM
#24
dom14
Then it must be the switch. Contacts might have become dodgy over many years.
Once a month for 20 mins isn't that bad, unless of course that 20 minutes happen to be on a long dark stretch in the middle of the pitch black night with no street lights, while you're doing 100+km/h.
Find it and fix it. Don't take any chances that are not worth it. Get a replacement switch from a wrecker. Cheaper and that way you can confirm the problem without spending a fortune.
switch has been replaced - I thought I stuffed it up when I was trying to open it to clean
so once I worked out how and why, I did the new switch
I am leaning towards a
loose plug
- but they are tight
