Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 51
Thread: Belt Tensioner Assembly (CRD)
  1. #41
    .......... TPC's Avatar
    63 Post(s)
    Quote Originally Posted by roofy View Post
    Have got a spare belt id try that first if not it will be the alternator
    New belt too? Or just the tensioner?
    I did not replace the belt as this was replaced recently with a genuine one and it looks new still.
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Id try another another one first
  4. #43
    Take the belt off and spin the a/c idler pulley and also the alternator pulley. They should spin nice. My guess the a/c pulley will be a bit on the rough side, they always are.
    BigRAWesty (23rd May 2016)
  6. #44
    My a/c one sh!t itself. Easy enough to just replace the bearing, if that's the problem.
    Sent from my XT1033
  7. The Following User Says Thank You to jay see For This Useful Post:
  8. #45
    Sent from my XT1033
    How hard of a job?? I've read they can be a biatch..
    I found a write-up somewhere, I dig it up later tonight when I'm on the computer
    Not hard at all.
    Sent from my XT1033
  10. The Following User Says Thank You to jay see For This Useful Post:
  11. #47
    @bigguwesty This is taken form the other patrol forum.Pretty much the way I did mine. I had it apart to replace the timing case seal at the same time.
    1- remove belt
    2- remove radiator shroud
    3- buy three 5x35mm cap head screws from bunnings or hardware shop to use as jacking screws to remove coverplate. screw jacking screws in a short way then with a screw driver between screws to stop pully turning undo the pully retaining bolt(13 or 14 mm socket) then screw jacking bolts in evenly until its off.
    4-with a 3 legged bearing puller remove pully
    5- remove bearing
    Job is easy, be very careful there is three small shims/washers behind the pulley retaining bolt. Don't loose those.
    Bearings are cheap and readily available at bearing supply shops
    Good luck
    I do recall there is a circlip that needs to be removed as well.
    __________________
  12. The Following User Says Thank You to jay see For This Useful Post:
  13. #48
    1- remove belt
    5- remove bearing
    Good luck
    __________________
    Sweet.. I might do both for good measure..
    From memory when doing my a/c the bearing wasn't real cheap. It was around 30odd dollars. But not too dear at the same time. If the bearing has never been changed before there will be like folded tabs over the bearing from the pulley. The pulley also flexes too when removing and refitting the bearing. So make sure when it flexes the centre of the pulley is in the same positionas it was when it came off the compressor.
    If it doesn't, the pulley will be out of alignment with all the other pulleys.
  15. #50
    Feb 2015
    Does anyone else feel that the torque setting for the tensioner BRACKET ie the large pivot bolt on the bracket, is set too tight?
    I am worried about it seizing but don't want the bolt to come out either if it's too loose.
