22nd May 2016, 09:03 PM
#41
roofy
Have got a spare belt id try that first if not it will be the alternator
mudski
New belt too? Or just the tensioner?
I did not replace the belt as this was replaced recently with a genuine one and it looks new still.
22nd May 2016 09:03 PM
22nd May 2016, 09:37 PM
#42
TPC
Id try another another one first
23rd May 2016, 04:42 PM
#43
Take the belt off and spin the a/c idler pulley and also the alternator pulley. They should spin nice. My guess the a/c pulley will be a bit on the rough side, they always are.
BigRAWesty (23rd May 2016)
23rd May 2016, 05:12 PM
#44
mudski
My a/c one sh!t itself. Easy enough to just replace the bearing, if that's the problem.
Sent from my XT1033
The Following User Says Thank You to jay see For This Useful Post:
23rd May 2016, 05:43 PM
#45
jay see
Sent from my XT1033
How hard of a job?? I've read they can be a biatch..
23rd May 2016, 05:47 PM
#46
I found a write-up somewhere, I dig it up later tonight when I'm on the computer
Not hard at all.
Sent from my XT1033
23rd May 2016, 07:43 PM
#47
@bigguwesty This is taken form the other patrol forum.Pretty much the way I did mine. I had it apart to replace the timing case seal at the same time.
1- remove belt
2- remove radiator shroud
3- buy three 5x35mm cap head screws from bunnings or hardware shop to use as jacking screws to remove coverplate. screw jacking screws in a short way then with a screw driver between screws to stop pully turning undo the pully retaining bolt(13 or 14 mm socket) then screw jacking bolts in evenly until its off.
4-with a 3 legged bearing puller remove pully
5- remove bearing
Job is easy, be very careful there is three small shims/washers behind the pulley retaining bolt. Don't loose those.
Bearings are cheap and readily available at bearing supply shops
Good luck
I do recall there is a circlip that needs to be removed as well.
__________________
23rd May 2016, 07:49 PM
#48
jay see
1- remove belt
5- remove bearing
Good luck
__________________
Sweet.. I might do both for good measure..
23rd May 2016, 11:13 PM
#49
From memory when doing my a/c the bearing wasn't real cheap. It was around 30odd dollars. But not too dear at the same time. If the bearing has never been changed before there will be like folded tabs over the bearing from the pulley. The pulley also flexes too when removing and refitting the bearing. So make sure when it flexes the centre of the pulley is in the same positionas it was when it came off the compressor.
If it doesn't, the pulley will be out of alignment with all the other pulleys.
28th May 2016, 12:32 PM
#50
Does anyone else feel that the torque setting for the tensioner BRACKET ie the large pivot bolt on the bracket, is set too tight?
I am worried about it seizing but don't want the bolt to come out either if it's too loose.
