31st January 2016, 03:36 PM
2nd batt in quarter
has anyone fitted a battery into the rear quarter panel ?
was thinking about fitting one or more smaller battery's behind the cover and have plugs accessible on the panel trim.
sorry if this has been covered i looked but i suck at searching.
31st January 2016 03:36 PM
20th May 2016, 08:29 AM
Hi garett did you end up putting in the battery in the quarter pannel by any chance. If so do you have any pics by any chance.
@garett
21st May 2016, 02:11 PM
still working it out at the moment thinking of building the wheel arches up to the windows and hiding it in there. but not started work on it. just in planning and saving.
The Following 2 Users Say Thank You to garett For This Useful Post:
blocko05 (24th May 2016), rusty_nail (23rd May 2016)
21st May 2016, 02:59 PM
I am he, fear me
If you want an alternative with a ton of grunt, small, super light weight and safe maybe try a Lithium Phosphate.
A couple of the motor bike size will be the same as about 75 AH lead acid and last heaps longer.
Price is a bit scary but coming down
21st May 2016, 06:43 PM
MudRunnerTD (22nd May 2016)
21st May 2016, 08:47 PM
i'm not keen on cutting out supports. with out bracing it. but those photos are very helpful. thanks
21st May 2016, 09:22 PM
garett
Nothing was cut mate..
There was a couple of brackets for the rear ac but all bolt in..
So no cutting anything..
21st May 2016, 09:32 PM
mines a gq and i'm pretty sure the bracing is welded. last time i had the trim off... rear a/c oooooh, nope i got none of that.
The Following User Says Thank You to garett For This Useful Post:
BigRAWesty (21st May 2016)
21st May 2016, 10:39 PM
garett
Ow sorry mate yea mines a gu..
If you remove the jack cradle that opens up a bit of room. Maybe a small 70-100ah battery in there..
The gq does come in a long way above the wheel arch and doesn't leave much depth in the pannel..
22nd May 2016, 07:56 AM
Don't forget, a lot of sealed batteries (Deep Cycle) can be laid on their sides and mounted under the floor area. No venting of corrosive fumes into cabin (yes, you need to vent any/every battery mounted in cabin) or steelwork.
