Page 82 of 101 FirstFirst ... 3272808182838492 ... LastLast
Results 811 to 820 of 1003
Thread: Hodge's new 4.2
  1. #811
    175 Post(s)
    I've called it i won't be doing it. I got no means , time or premises to do it so to workshop it goes.
    I chickened out of cutting mine too, only cost a slab of crownies to the panelbeater. He said don't use a grinder, and used an air hacksaw.
  4. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    BigRAWesty (11th May 2016), Rocket55 (11th May 2016)
  5. #813
    43 Post(s)
    Less sparks, less finish work.
    Either a hacksaw or piston nibblers (drill powered ones) work well and leave a nice clean edge..
    Just make sure you use em on a clean flat surface.. the shavings are half moon shaped spikes from hell!!!!
    Aug 2014
    Perth
    10 Post(s)
    I took mine to a panel beaters and they cut the hole, welded a piece into the bonnet, painted the bonnet and scoop and fixed some holes and resprayed my left hand guard for $900 cash
  7. The Following User Says Thank You to gubigfish For This Useful Post:
    mudski (11th May 2016)
  8. #815
    Patrol Guru Rocket55's Avatar
    Sydney
    3 Post(s)
    I used an air hacksaw for mine, worked a treat .... Twice.
    Cheers Rod
    _______________________________________________
    Bitumen ...... Another watse of public funds
    My Build 2005 TD42TI
  9. The Following 2 Users Say Thank You to Rocket55 For This Useful Post:
    BigRAWesty (11th May 2016), Hodge (11th May 2016)
  10. #816
    175 Post(s)
    @mudski @Rocket55
    How are your fans for the inter cooler wired up? There is not a single bit of info or instructions on how it's meant to be setup.
    There is a blue wire in the loom I believe, so is it intended to be constant on with IGN ?
    For some reason I believed/though the fan was thermally kicked in. My bad.
    North brissy
    Dont fit it....
  12. #818
    There's ignition power in the wiper motor. Thats the easiest spot to get power.
    The blue wire would go here.
  13. #819
    175 Post(s)
    Yeah that's where I already got ign from for my Redarc. So I'm guessing it is meant to be like that always on when ign on ?
    175 Post(s)
    Dont fit it....
    Not a fan of a fan Mat ?
