Sweet FA. everything ive read says nadda. Apparently the problem is a plastic pin 3mmx6mm that simply wears out. I smashed the fark out of mine and cant find the worn bit now
have you thought about upgrading the door to an ST door so that you can prevent this happening again? would that stop your problems?
