Results 11 to 20 of 34
Thread: Just picked up my very first Patrol
    Expert Dan02's Avatar
    Apr 2016
    Petre, Bris, QLD
    ok so its booked in for wheel align this week and a general once over with a grease gun, hopefully they can sus the wobble.. then have to wait to the 24th for new 3inch stainless exhaust fit. by then the awning should have arrived so hopefully get that fitted and any other bits I can dig up.
    Apr 2016
    Petre, Bris, QLD
    Quote Originally Posted by Bigcol View Post
    was the car running hot at the time -
    at the bottom of the Radiator is a thermal switch, when it activates, it turns the aircon off to help cool the engine
    once engine temps lower, it switches off again, and your aircon is running fine...............
    mate i hope it wasn't anywhere near overheating,,, car empty and due to the wobble only doing 80km so bugger all load and its way out of summer.
  4. #13
    109 Post(s)
    Hey Dan, not sure if this is your first 4x4 but considering you're planning on Bribie Is, Fraser Is and I presume other beach locations, please be fully aware of the risks of using a towball during a recovery. You may already know this, but just in case you dont please have a read of the link below. We all began not knowing about the serious risks involved with towball recoveries.
    http://www.nissanpatrol.com.au/forum...ghlight=deaths
    Be safe and enjoy your new "freedom machine" mate!
  5. The Following 3 Users Say Thank You to Plasnart For This Useful Post:
    Bigcol (3rd May 2016), Dan02 (3rd May 2016), Woof (18th June 2016)
  6. #14
    BUT
    it could be Anything in the front end causing the wobbles
    Yep. My fix was to tighten the wheel bearings up a bit more. Lol.
    Nice ride too Dan.
  7. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Bigcol (3rd May 2016), LostBenji (19th May 2016)
  8. #15
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    hi
    my fix for the wobbles was swivel hub rebuild. king pins were gone. and radius arm bushes and drag link bushes were also stuffed
  9. #16
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    Quote Originally Posted by Dan02 View Post
    in that case, sounds like a loose connection on the Air Con pump
    have a look at the wiring, it may be old and just need a clean up on the terminal
    if not that, then check behind the dash for loose wiring -
    has the radio been changed? maybe didnt put the earth to a good spot
    Nissan's are bad for earths - really bad
    intermittent faults are usually an earth problem
  10. #17
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    @Bigcol fixed it for you.
  11. The Following User Says Thank You to 4bye4 For This Useful Post:
  12. #18
    Apr 2016
    Petre, Bris, QLD
    am sure this has been covered elsewhere but just a quick thought - am getting a 3" exhaust system installed soon. Mech says it should significantly improve power like around 20 - 25% over the stock existing one. thought that sounded a bit high or is this a realistic target. also, as the current stock exhaust is still working should i be doing anything else before that.
  13. #19
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    a 3" will be ok, as long as it is a "hi-flow" and also your muffler is a good "hi-flow" one as well
    the idea is to get the engine breathing out easier, so, apart from most sounding like 747's at idle, they sound pretty darn sweet as well
    even if I do say so myself
  14. The Following 2 Users Say Thank You to Bigcol For This Useful Post:
    BigRAWesty (4th May 2016), Dan02 (3rd May 2016)
  15. #20
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    Quote Originally Posted by 4bye4 View Post
    dont laugh, I know a guy with a rubber strap from the body to the ground - conveyor belt mind you, steel core - just as an added Earth
