28th April 2016, 10:37 PM
taslucas
I'm not trying to do anything on a Patrol but I bought a cheap Bluetooth plug for my commy after reading up on an Ls1 forum. I also bought the android app called Torque and just had a little go with it. Looks like it'll work really well and the guys off the ls1 forum were having a lot of success with the same setup. If it works as well on a Patrol then I'd say it's a great investment and at $15 for the plug and $5 for the full app it's a very cheap alternative to a scan guage or equivalent
>>>tappin from tassie
I run an obd2 bluetooth adapter and torque on my android headunit in my 2012 Patrol, Use it to monitor speed, fuel rail pressure, water temp etc.
Works really well.
1998 GU RD28T: RIP
1996 GQ RD28T: RIP 11 days later
Hello 2012 GU CRDZD30
Nissan winchbar + Warn, Dual Battery/Redarc, UHF and Titan rear drawers
The Following 2 Users Say Thank You to trekster For This Useful Post:
jay see (28th April 2016), taslucas (29th April 2016)
28th April 2016 10:37 PM
28th April 2016, 10:49 PM
trekster
Works really well.
That is exactly what I want to do, but I haven't yet found a way to do it with mine.:banghead:
29th April 2016, 07:51 AM
jay see
Be sure to report back.
And if you can cast your phone to your radio, you left it plugged in and have live information.
I don't get that bit? All the info is live.
There's a guy on the ls forum that has combined dash cam, gps and torque information to end up with a gps pinned video with map and gauge overlay on it. Pretty tricky!
>>>tappin from tassie
Hello from Under Down Under!
29th April 2016, 08:15 AM
taslucas
>>>tappin from tassie
If you leave the BT unit plugged in always and your phone and radio are compatible you can mirror what's on your phone to the radio. Even better if the radio supports apps, run the torque app straight out the radio.
It's endless what can be done now.
29th April 2016, 08:22 AM
Ahh yep I get you now. I have installed the app on my old phone which has a very big screen so that can be dedicated to the app. Apparently the plugs chew a bit of power if left in continuously.
Which app were you using?
>>>tappin from tassie
29th April 2016, 08:32 AM
taslucas
>>>tappin from tassie
Same. Torque, but the lite version found that it was enough to find the fault and reset it.
Really would like to be able to use it in the Patrol.
29th April 2016, 08:36 AM
#17
I have a Jaycar wifi one, i originally bought the blue tooth one but could not get it to work so took it back & swapped it. I bought it to fault find the Hyundai & plugged it into the 'troll (GU8), using the free app I could look at many parameters. I made the mistake of leaving it plugged in & flattened the battery when the car was not used for 3 weeks.
Graham
29th April 2016, 10:22 AM
#18
I lashed out the whole 5 bucks for the pro version straight up lol.
My plug was from a Melbourne seller and cost 15 bucks. Logged data on the drive to work today and emailed it to myself.
I can open the spreadsheet but the other two files are .kml files. I think they're to do with the google maps stuff. What opens them?
>>>tappin from tassie
The Following User Says Thank You to taslucas For This Useful Post:
jay see (29th April 2016)
29th April 2016, 02:55 PM
#19
taslucas
>>>tappin from tassie
Try Google earth
The Following 2 Users Say Thank You to gubigfish For This Useful Post:
taslucas (29th April 2016), the evil twin (29th April 2016)
29th April 2016, 03:34 PM
#20
I am he, fear me
gubigfish
Try Google earth
Yep... the .kml file should open in Google Earth and show you the track you took (as a series of points IIRC)
The Following 2 Users Say Thank You to the evil twin For This Useful Post:
jay see (29th April 2016), taslucas (29th April 2016)
