Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Do GU's run the OBD2?
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Do GU's run the OBD2 plug/software?
    >>>tappin from tassie
    Hello from Under Down Under!
    Sort of... the Di's aren't fully compliant but the CRD's are.
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    taslucas (28th April 2016)
    SUCH IS LIFE Maxhead's Avatar
    ACT
    all the 3l will have OBDII plug but CRD and DI use different protocols.
    Not sure with the 4.2 and 4.8
    What you tying to do?
    ________________________
    ______ 2017 D-Max _______
  6. The Following User Says Thank You to Maxhead For This Useful Post:
  7. #4
    I've got the grey plug, can't remember what it's called, this the 14 pin one.
    I've used a cheap WiFi obd2 on the wife's VE commo, without any issues. Would like to do the same with the Patrol.
    However mines a early series 1.
  8. The Following User Says Thank You to jay see For This Useful Post:
  9. #5
    Aug 2011
    North West Tas
    56 Post(s)
    I'm not trying to do anything on a Patrol but I bought a cheap Bluetooth plug for my commy after reading up on an Ls1 forum. I also bought the android app called Torque and just had a little go with it. Looks like it'll work really well and the guys off the ls1 forum were having a lot of success with the same setup. If it works as well on a Patrol then I'd say it's a great investment and at $15 for the plug and $5 for the full app it's a very cheap alternative to a scan guage or equivalent
    >>>tappin from tassie
  10. #6
    99% chance it won't work.
    Something to do with a particular character or somesuch missing in the OBD11, probably deliberately by Nissan.
    It meant that Consult works but generic OBD11 didn't until Series 5 or later (not sure about TB48's)
  11. The Following User Says Thank You to the evil twin For This Useful Post:
  12. #7
    Aug 2011
    North West Tas
    56 Post(s)
    A couple of mates have GU's so I'll give it a go. I'm not up with the series but one is a 98 2.8 and the others are around 2002-4 3lts
    >>>tappin from tassie
  13. The Following User Says Thank You to taslucas For This Useful Post:
    jay see (28th April 2016)
  14. #8
    >>>tappin from tassie
    I managed to fault find an o2 sensor after an engine light came up, even down to which one out of the 4.
    I like this better than a scan gauge because it's mobile and it works well, oh and it cheap as....
    Yep, your right, even brought a adapter cable to suit the two different plugs and still no good.
  15. #9
    Aug 2011
    North West Tas
    56 Post(s)
    Yeah it appears you can do a lot with the commy. The logging feature looks good
    >>>tappin from tassie
  16. The Following User Says Thank You to taslucas For This Useful Post:
  17. #10
    >>>tappin from tassie
    Be sure to report back.
    And if you can cast your phone to your radio, you left it plugged in and have live information.
