Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: starting to collect bits to do a turbo conversion ....
    Mar 2015
    im not sure what a kw is talk HP im old school lol
    ahhh ok so even the log manifolds are rubbish ................
    and the brand name kit you speak of it has the compleate exhaust in it yeah ??????
    and what do you mean by a well built 11mm pump ??? extra work done on the inside to get the flow rate up ?? or just a rebuilt pump but done by someone who knows what there doing
    thanks i am takeing this all on board i may run it na to start out ...... the original nissan log any good or not worth the trouble just get a after market one ??
    i do appreciate your help
    kw is easy. Just times it by 1.34 roughly to get hp. KW goes with NM. HP goes with FT/LB.
    The cheap log manifolds are. Radius Fabrication do a reasonable manifold for decent money. You can also keep an eye out for a factory manifold from a td42t.
    Yes the kits come with complete exhaust. This one for example. Add 550 for a complete 3" exhaust. So around 3300.
    http://www.ebay.com.au/itm/DTS-TURBO...25.m3641.l6368
    You can get 11mm pumps that have higher outputs than a standard item. There are only a few people who do a nice higher output 11mm.
  4. #13
    Mar 2015
    ok sweet so i will need around 10 g to do this lol
  5. #14
    465 Post(s)
    Dont forget the intercooler. If you havent already or have one etc etc. Turbo, pump and intercooler will suck up the best part of 10k too. Depending on what you decide for that is....
    Injectors too. Theres 700ish on them...
    From my experience. Think of a conversion like a house reno. Have a budget and then double it. Lol
  6. #15
    $700 for injectors is daylight robbery. Please tell me you didnt pay that much.
    3300 for the dts kit with 3" exhaust.
    300 for gauges.
    500-2000 for an intercooler.
    2-3000 for pump with injectors.
    If you get handy there is no reason you couldnt do it for about 7k
  7. The Following User Says Thank You to nissannewby For This Useful Post:
    BigRAWesty (22nd April 2016)
  8. #16
    465 Post(s)
    Hence the ish i put on the price. I couldn't remember the exact price....
  9. #17
    Mar 2015
    well i think i found a 11mm pump on facebook waiting for a reply used but 500 dollars so there is a start.....
    the rest will come as i get the cash together
