Results 11 to 20 of 23
Thread: How to use a HELI Coil tool to repair a stripped thread.
    Good write up< TD. I recommend using anti seize on the bolt or stud that goes into the helicoil, because if the seize they will destroy the helicoil and make it very hard to repair.
    Excellent Idea as you have two dis-similar metals your bound to get electrolysis.
    Never seize would be perfect
    http://www.ebay.com.au/itm/161848123...%3AMEBIDX%3AIT
    174 Post(s)
    Is this an unusual thermostat housing? Most I recall seeing just have plain holes with the bolts screwing into threaded holes in the surface the housing mates to.
  4. The Following User Says Thank You to Cuppa For This Useful Post:
    Nightjar (24th April 2016)
  5. #13
    465 Post(s)
    Its off a ZD30 cuppa. it bolts up a real different way to how you would think.
  6. #14
    Quote Originally Posted by Touses View Post
    Handy DIY that 3D. Does the helicoil require a bit of thread locker, as a just in case, for vibration?
    I always, well after it happened to me years ago when i didn't, I subsequently always put Loctite on the helicoil and anti-seize on the bolt.
    Nothing is worse than trying to undo the bolt at a later date and realising the bloody helicoil is coming with it
  7. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    growler2058 (23rd April 2016), Touses (23rd April 2016)
  8. #15
    Nov 2014
    Waikiki, WA
    Great invention, has probably saved many costly replacements.
    2002 ST Coilcab, Chevy 6.5 V8 Garrett turbo, intercooled. 3.9 diffs, Cooper AT3 265/75/16.
    Trailstar Aquila 5.4
    http://s4.zetaboards.com/Gold_Detecting/index/
    http://www.youtube.com/watch?v=y7GCkFcHsh0
  9. #16
    Quote Originally Posted by Nightjar View Post
    Somewhere,,, some one is sitting on a beach drinking a drink with an umbrella sticking out of it........lol
  10. #17
    The thermostat "housing" is part of the block say similar to a starter motor
    The bolts go through the block and then screw onto the thermostat housing, LOL
    Being dis-similar metals you're bound to get electrolysis and this is where the problem
    begins, they bond together and thats that...lol
  11. #18
    I think loctite 243 would be the go from memory not sure of the heat rating though.
    Here's a pic of the thread once removed from the bolt lol
  12. #19
    Feb 2011
    Shed
    45 Post(s)
    Me very soon
  13. #20
    Me very soon
    Oh shite is it that time of year already ????
