Results 11 to 20 of 22
Thread: Need help wiring water temp gauge please
    Ok changed the sender with no luck
    where do ppl put after market senders on a ZD30??
    So nobody with a ZD30 is running an aftermarket water temp gauge ???
  4. #13
    175 Post(s)
    John. I'll repeat my post earlier... If your sender is in on the HOSE, it may not be grounding the sender hence it won't work.. It needs to be on a metal / grounded part of the cooling system like the block or thermostat housing or something...
    I "think" that's how those senders work. ET or someone else correct me if I'm wrong...
    I ran an extra wire off the sender to the earth on my AUX battery ..
    All that happened was the gauge showed 150 degrees instead of 40,,,
    even changed the sender {no change}
  6. The Following User Says Thank You to threedogs For This Useful Post:
    Hodge (21st April 2016)
  7. #15
    175 Post(s)
    Ok, so I was wrong. So, if two senders are doing the same thing. Could something be up with your gauge ?
    Yeah Im sorting it out with the seller as we speak. lol
  9. #17
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    This doesn't make sense. Where did you connect this extra earth wire on the sender?. On the outer housing that screws into the pipe or the threaded end that the green wire is connected to?
    If it was on the threaded end then I would expect the gauge to read maximum.
    If it was on the outer housing I would say the sender unit is the wrong type for a gauge and the outer housing/pipe doesn't have a permanent earth.
    Not sure why you are bothering fitting a cheap dragon temperature gauge when the ECUTalk will give a more accurate reading. A low coolant alarm would be more beneficial.
  10. #18
    brisbane
    Mines in the top hose. I thought that's where everyone puts them.
  11. The Following User Says Thank You to megatexture For This Useful Post:
    threedogs (22nd April 2016)
  12. #19
    Because more gauges look more super cool when they're lit up at night? ???
  13. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    Avo (22nd April 2016), threedogs (22nd April 2016)
  14. #20
    @ Mega I take it you used one of those alloy billet sender holder?
    Did you jus cut the top hose or source shorter ones to do the job.
    http://www.ebay.com.au/itm/HOSE-ADAP...wAAOSwGzlTv4-x
