Results 1 to 8 of 8
Thread: DIY projector headlights on GU
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Thumbs up DIY projector headlights on GU
    Hi all just sharing how I did my headlight projector install
    Started with this kit from fleabay
    http://www.ebay.com.au/itm/301792681...%3AMEBIDX%3AIT
    Remember to order with RHD Cut out option also choose your angel eyes colour and the hid temperature
    Also got some demon eyes from the same seller for some extra bling
    http://www.ebay.com.au/itm/Pair-Devi...-/301829657195
    Here is rhe kit all unpacked
    And the demon eyes
    I used a heatgun to soften up the sealant then pried off the glass just take your time and keep applying heat as needed
    Also used one of my trim removal tools to remove the glass found that starting from the bottom was best
    Remove the outer shield two Philips screws
    Now remove the reflector by undoing the headlight adjuster screws on the back of the light then a bit of force to get it off the clip
    Now remove the globe holder spring and shield held in by a small Philips screw and discard
    Time to paint the reflector and outer shield if you choose to this is an option I wanted mine black so in to the paint booth it went first for a coat of adhesive promoter
    So while paint is drying remove the globe holder on the projector I also installed the demon eyes at the same time image.jpegimage.jpeg
    Now fit the H4 size silicone washer from the kit ready for installation I chose to seal of the back of the projector with aluminium tape as I found the demon eyes was reflecting out the back
    Couple of coats of flat black and ready to come out of the paint booth lol
    Now with clean hands start assembling careful not to scratch the new paint job
    Fit projector into reflector housing making sure the wires go in the bottom slot select the H4 washer from the kit and tighten up the nut
    Fit the globe holder and the hid globe and then back into the light housing start the two adjuster screws first then press on to the stud
    image.jpeg[ATTACH=CONFIG]66091[/ATTACH
    Fit outer shield and refit the glass remember to blow out light with air and clean the inside of the glass
    All done now repeat for the other side and done job took approx 4 hours from go to whoa there is a complete wiring harness that comes in the kit witch is nearly all plug and play wee bit of soldering for the Angel and demon eyes easy done here is the end result
    Send from my iPad cos this site rocks now on the tablet now that @AB fixed it
  2. The Following 5 Users Say Thank You to Kimbo63 For This Useful Post:
    BigRAWesty (7th April 2016), Clunk (7th April 2016), Filterselite (11th April 2016), lucus30 (11th April 2016), Touses (8th April 2016)
    43 Post(s)
    Awesome write up.. thanks
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Kimbo63 (7th April 2016)
  6. #3
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Quote Originally Posted by Kimbo63 View Post
    And the demon eyes
    Send from my iPad cos this site rocks now on the tablet now that Andy fixed it
    Sweet you wanna do me a set?
    Lucus30's 1999 GU ST TB45E
  7. #4
    Dec 2015
    Perth WA
    5 Post(s)
    Just follow the step by step instructions Lucus lol
  8. The Following User Says Thank You to Kimbo63 For This Useful Post:
  9. #5
    Sep 2013
    16 Post(s)
    yeah im not sure I have the finesse for it. I need to buy some new headlights soon so will probably buy some and do it then.
    Not sure what brand though... maybe depo?
  10. The Following User Says Thank You to lucus30 For This Useful Post:
  11. #6
    Dec 2015
    Perth WA
    5 Post(s)
    Thanks mate really wasn't too hard a good heatgun is handy but also would have like to do the job on new lights but came out OK handy hint on the original Nissan lights don't forget the adjusters are left hand threads
    Cheers Kimbo
  12. The Following User Says Thank You to Kimbo63 For This Useful Post:
  13. #7
    465 Post(s)
    Nice job mate. Ive had mine, same as your but i have blue devils eyes, for 18months or so and i love the light output.
    I found it easier to put the entire light in the oven as i found keeping the heat even hard with the heat gun.
    Lucas, Depo are the best in aftermarket lights.
  14. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (8th April 2016), Kimbo63 (8th April 2016)
  15. #8
    Dec 2015
    Perth WA
    5 Post(s)
    Must say light output is amazing thought I would add this
    Saves any one wanting to do this digging it out the manual
  16. The Following User Says Thank You to Kimbo63 For This Useful Post:
    mudski (13th April 2016)
