Results 1 to 10 of 16
Thread: Car stands
    Whyalla SA
    Car stands
    I have to do a bit of rewiring under the patrol. It's a tight squeeze. I want to work on the front end, engine bay.
    I was looking at putting it on stands.
    I am some what inclined to place it on 4 stands and also block under the wheels, just in case.
    The stands are 3t rated.
    So should I put it on 2 stands up front and block the rear wheels, or just put the whole chassis on 4 stands?
    I only ever use 2 stands... mainly because I only have, yep, you guessed it, 2 stands...
  4. The Following User Says Thank You to the evil twin For This Useful Post:
    outback (11th November 2015)
    465 Post(s)
    Rear wheels are better support for the car than stands. So stands on the front only, chock the rear wheels. I also leave the trolley just under the diff as extra support. If the wheels are coming off, throw them under the chassis rails too.
  6. The Following 3 Users Say Thank You to mudski For This Useful Post:
    Hodge (10th November 2015), macca (24th March 2016), outback (11th November 2015)
  7. #4
    Whyalla SA
    Wheels aren't coming off, but I intend to place some blocks under them anyway.
  8. #5
    Mar 2016
    I live in hobart tasmania
    Yep,what mudski said
  9. #6
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    i made some ramps for when i don't have to remove wheels. solid timber. drive on drive off. easier than jacking and no chance of it falling. but just 2 is fine with chocked wheels
  10. #7
    43 Post(s)
    Personally if not taking the wheels off drive the rear up onto ramps and Jack the front up for stands..
    Hardcore
    central coast nsw
    I have 4 x solid timber ramps, and use low range getting up onto em
    you may be surprised at effort needed to mount 4 ramps at once safely!
    Or 2 ramps on front, chock rear,and safety jacks under front chassie or axle.
    Car ver's Man = CAR WINS if it falls off!.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  12. The Following User Says Thank You to Robo For This Useful Post:
    BigRAWesty (24th March 2016)
  13. #9
    Oct 2010
    Old Bar, NSW
    Maybe have a death wish, have used 4 HD stands for years. Sometimes leave the trolly jack under the diff if its out of the way.
    Once its on the stands, it does get a good shake to make sure its solid though.
    Macca
  14. #10
    465 Post(s)
    Yeah i always give the car a good shake too. Just so the car can settle on the stands if it needs.
  15. The Following User Says Thank You to mudski For This Useful Post:
