21st March 2016, 08:11 PM
#7941
The Mad Ozzy
Saw the new spinal surgeon today to find out all the previous scans and discograms were done incorrectly and and the reports meant nothing.
Now have to start all the scans again from scratch to get them right and finally (hopefully this time) find out what the hell is wrong and get it fixed.
Just what I need, all the discs being injected and pressurised again, friggen hurt bad enough last time....argh
Never underestimate the power of the tap, let it flow through you.
www.swat4x4.com
The Following User Says Thank You to oncedisturbed For This Useful Post:
threedogs (24th March 2016)
21st March 2016 08:11 PM
21st March 2016, 08:14 PM
#7942
biggqwesty
Well today has dented my wallet quite a bit to the point I'm nearly contemplating missing the may trip..
Lights started flickering in the shed this morning and then all power lost..
Shed is run from house line so house lost most power to..
Wife comes out and says the fuse box is crackling and popping..
That's not good..
Grab a bit of timber dowel.
Open the box to smoke and popping..
Breaker not tripped, mains still on..
So first thing was trip the breaker and kill the main..
Still popping..
We still had the old ceramic fuse wire setup and it turns out previous owners doubled up the wire..
Fark..
It had melted the wire off the back of the fuse block..
We are so lucky that it burnt out in the box and not the roof..
But still it's $900 as the old setup was toast.. all fittings and screws were stuffed..
Ok the upside it's all proper and up to spec again..
On the downer is we only have 6mm mains cable coming in and a 40A fuse on the house..
So any future shed will mean new mains upgraded to carry the extra load..
And in now $900 down..
Insurance?
#7943
Dribble Master
oncedisturbed
Let's hope for a better outcome this time mate
21st March 2016, 08:35 PM
#7944
Clunk
Far out, $900, I know a bulknof this would have been labour but what was replaced?
The whole board and re wired.. the only bits left alone were the meters..
nissannewby
Insurance?
I doubt it.. it was caused by the idiots prior to use..
What angle are you think of though?? It's worth asking.. will save me some cash..
21st March 2016, 08:57 PM
#7945
The 747
biggqwesty
Your switchboard caught fire because of a faulty fuse
21st March 2016, 09:12 PM
#7946
taslucas
A couple of drops of dishwashing liquid in a cup of water to dip your finger in works great
>>>tappin from tassie
I tried just water and it stuck to me and was setting very very quick. I'll add some soap next time. Learning allot the hard way
21st March 2016, 09:14 PM
#7947
Winnie
Yea an old ceramic with fuse wire which had been doubled up..
Not sure how it'll go
21st March 2016, 09:52 PM
#7948
biggqwesty
Well it would have passed a building inspection before purchase? It should be covered. Its certainly worth the call anyway.
BigRAWesty (22nd March 2016)
21st March 2016, 10:02 PM
#7949
Travelling Podologist
Sounds like you were indeed lucky & upgrading is for the best. So you have proper circuit breakers/RCD's now in place of fuses now?
22nd March 2016, 02:30 AM
#7950
Patrol Goddess
biggqwesty
And on a true angry note WTF is up with new tapatalk app.. Geeze it Sucks. .
No more search function.. you can only search in subforums
And mine now has an ad at the bottom of every page.
KATROL- The 2nd
GU TD42TGi
Silent member 1208
