Results 1 to 10 of 14
Thread: GU LHF Power window intermittently not working
    Advanced ando89's Avatar
    Mar 2016
    Perth, Western Australia
    My GU patrol Left Hand Front Window intermittently won't work. I have already replaced the motor and assembly. Before i go and replace switches and rip out wiring shortly followed by burning the car does anyone have a schematic of the electrical system i can get a copy of or can tell me what it the most likely cause.
    Thanks in advanced
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    PM yendor mate.
    Is it only that window? Is it faulty with both switches, or just one switch?
    Nov 2010
    Getting a life...
    38 Post(s)
    Clean the switches. They fill up with dust 'n' stuff.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Ditto. Take the switch out of the offending door and pull it apart and clean the contacts. It is a very easy quick job. A little finicky but simple.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  6. The Following User Says Thank You to Chubba For This Useful Post:
    katwoman (18th March 2016)
    Mar 2016
    Thanks for the quick replays fellas. i=It doesn't matter what switch i use master switch on drivers side or the switch on the door. ill have a crack at cleaning them then see what happens. Worst case ill have to run a new wire.
  8. #7
    Mar 2016
    Nandewar Ranges, NSW
    10 Post(s)
    Had the same problem a few years ago with my GU. Seemed to be coming from a loose connection on the wiring behind the LHF kick panel. I had run some antenna coax & electrical wires thru there a couple of days before. Gave the harness a bit of a jiggle and it has been good ever since. Might be worth a look.
  9. The Following User Says Thank You to VK2FMIA For This Useful Post:
    ando89 (17th March 2016)
  10. #8
    Mar 2016
    Thanks mate ill give that a look before i go running new wires. This problem has been around ever since i have had the car going on 3 years. i know i know I'm lazy but i HATE electrics pretty bad for a diesel mechanic i know since everything have a wire or 10 hanging off it now days
  11. #9
    Also try re-doing a few of the earth straps for up the front of the Patrol.
    You'll find the Patrol has earths for different portions of the car, eg engine
    bay, dash, front passenger area then motor to chassis and motor to chassis
    It goes on and on but you need to look after your earth straps
  12. The Following User Says Thank You to threedogs For This Useful Post:
  13. #10
    Mar 2016
    thanks fellas and lady ill have a look at all of them with any luck ill find the issue without to much hassle
