9th March 2016, 07:46 PM
#2401
garett
a o ring ... damn they aren't cheap
I hope your joking....
9th March 2016 07:46 PM
9th March 2016, 09:01 PM
#2402
Patrol Guru
Just put the money down on a new set of rubbers and rims. Km2's on steelies.
The Following 2 Users Say Thank You to Covo71 For This Useful Post:
BigRAWesty (9th March 2016), megatexture (10th March 2016)
9th March 2016, 10:20 PM
#2403
Covo71
What size and how much a corner if you don't mind me asking
9th March 2016, 11:37 PM
#2404
I bought a wiring loom, new washer bottle and washer motors, and series 1 lights so people stop almost running up my back end when they tail gate me.
9th March 2016, 11:48 PM
#2405
50A solid state relay
90-110 psi cut off switch
50 degree thermostat switch.
Small barn door extension bracket..
Next is a compressor switch and led light bar switch.
10th March 2016, 08:00 AM
#2406
biggqwesty
I went for red switches mainly as they dont glare at night and very easy
on the eyes
10th March 2016, 10:17 AM
#2407
I am he, fear me
lucus30
Measured with a clamp metre it wasn't quite 10amp some thing like 9.7 but close enough for me.
Even 8.5 amps I'd be stoked with. Fridge draws about 4 so even if it was running constantly id be in front
I do have another 120w foldable if i ever needed more juice
Clamp Meters will often give some 'unusual' readings on low current DC.
Budget for a max of 8 amps and you won't be dissapointed
I have a 100 Watt blanket and it reliably produces 5 amps without getting too anal about angles and moving it every 30 minutes
10th March 2016, 10:19 AM
#2408
Hardcore
the evil twin
Clamp Meters will give some 'unusual' readings on low current DC.
Yeah I know they aren't perfect... However it is a good fluke meter so I'd hope it would be as accurate as you could get for a clamp meter
Lucus30's 1999 GU ST TB45E
10th March 2016, 11:19 AM
#2409
Bought a "winch in / winch out" carling style switch for "in-cabin" winch control. Not going to wire it up the traditional way. Going to wire it to a warn winch plug and only plug it in when required.
Bazza
10th March 2016, 05:54 PM
#2410
Enjoying the trips
lucus30
Bought the 150w solar blanket too. Lying on my bonnet the other day I was getting 10 amp gotta be happy with that
Got it today, had an old battery to try and recharge so hooked it up with the blanket flat on the drive at 2.00 pm saw 6 amps on my clip meter.
The high voltage light was on which means the battery if already fully charged, that is not the case. It also doesn't work at all on the Redarc BCDC solar input either.
Give it good test over the weekend and compare it to the folding 120watt panel I have.
Macca
The Following 2 Users Say Thank You to macca For This Useful Post:
BigRAWesty (10th March 2016), megatexture (10th March 2016)
