Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 57
Thread: DIY -Ryco A360 flat panel airbox with 4" in/out
  1. #31
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    How did you bend the sheet? Have you got a bender or you do it a different way
    Lucus30's 1999 GU ST TB45E
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Quote Originally Posted by lucus30 View Post
    I have a length of angle iron fixed to my press to work like a homemade panbrake.
    I bent the small end in my vice. It's only 1.6mm same as exhaust pipe
    John
  4. The Following 3 Users Say Thank You to jff45 For This Useful Post:
    BigRAWesty (19th February 2016), lucus30 (19th February 2016), mudski (19th February 2016)
  5. #33
    Sep 2013
    16 Post(s)
    Nice!!! I'll swap workshops with you ha ha
  6. #34
    I got the same press. By mine is red. I'm trying to work out how to bent that sheet....
  7. #35
    Morayfield, QLD
    13 Post(s)
    Are you asking how it works?
    John
  8. #36
    Hmm yeah for curiosity. If it doesnt take too many words to do.
    Bloodyaussie (19th February 2016)
  10. #37
    Morayfield, QLD
    13 Post(s)
    If you look at the 2nd pic, you'll see one side of the box bent up. The angle iron swings up 90 degrees.
    The press is holding the rest of the sheet firm while a side is bent up.
    If you look closely, you'll see a steel tube sticking out under the angle iron. I put a round steel bar in there to lift the angle iron up.
    It's the principle of a panbrake but a bit ghetto..
    In the 1st pic you can see the bolts in line with the edge if the angle so it pivots along that line.
    John
  11. The Following User Says Thank You to jff45 For This Useful Post:
    mudski (20th February 2016)
  12. #38
    Gotcha, so the angle iron pivots upward to bend the plate, and the press holds the plate down. Ingenious.
    jff45 (20th February 2016)
  14. #39
    Morayfield, QLD
    13 Post(s)
    Finally got the 4" elbow through the inner guard. Tried to do it all from the engine side but you can't do a neat job without removing the mudguard.
    It was easier than I'd thought to remove.
    This elbow gets rid of a restriction that the last bend of the snorkel has.
    John
  15. #40
    330 Post(s)
    can you post a pic of the seat for the filter? is it founded on the edge of the lower box or s there a rebate folded there? i can't quite make it out? Also some dimensions on that unfolded flat plate would be wicked! i am very keen to adapt this to something for my GQ.
