17th February 2016, 08:32 PM
17th February 2016 08:32 PM
17th February 2016, 10:18 PM
I had to use a Dakota Digital tachometer converter to get my TB45 tachometer to work properly. I think I recall a thread elsewhere where they had to do that too with a 2.8.
That plug you're showing is a Deutsch plug, not the standard Nissan plug, so someone has already tried to connect something there.
John
17th February 2016, 10:25 PM
The tacho signal comes from the 2.8 ECU. Does your vehicle still have the 2.8 ECU fitted?
The ECU use to receive the RPM signal from the camshaft position sensor mounted in the injector pump.
In the original harness that went to the injector pump there should be a black and a white wire. These two wire connect to the two wires in your photo.
To confirm you have the correct wires. Disconnect the ECU and with an ohmmeter confirm :
The white wire goes to pins 41 and 45.
The black wire goes to pins 28 and 33.
The Following User Says Thank You to Yendor For This Useful Post:
mudnut (17th February 2016)
17th February 2016, 11:03 PM
I'm pritty sure the ecu has been taken out, I've never seen one in there when I've been tinkering around. Where does Nissan usually hide them?
18th February 2016, 07:47 AM
jaido
Its should be pretty much beside your left foot, ontop of the transmission tunnel, and above the heater floor outlet, or there abouts. Square flat box about 6 inches square and about an inch or so thick.
18th February 2016, 09:24 AM
If you no longer have the ECU but can locate the plug that went into the ECU, you will find a yellow/black stripe wire on pin 5.
This wire should be connected to your tacho.
You can try to connect 1 of your tacho sender wires to this yellow/black wire and the other to earth.
John
18th February 2016, 12:11 PM
mudski
is that the wiring for the ecu? looks like thats all gone.
18th February 2016, 12:39 PM
#8
Isn't that a yellow/black stripe wire I see roughly where pin 5 would be?
If it is, it should be connected to the tacho.
John
18th February 2016, 01:00 PM
#9
Sure was, so I cut it off connected it to the green wire and the blue to earth, did nothing.
Swapped them around and still nothing.
18th February 2016, 01:05 PM
#10
Alrighty I got something,
Green wire going to the yellow-bk
And blue to earth, BUT at idle I have nothing on the tacho and when I start accelerating the tacho starts going up
