Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 79
Thread: rear draws from 4wd action
  1. #51
    Feb 2016
    Sydney
    Thanks katwoman ans mudski.
    We're probably getting a 65l waeco. Taller than both of yours and side hinge rather than end hinge on the arb so I have a feeling this might be an issue.
    I'll have to have a really good measure up but I may have to reconsider building my own.
    43 Post(s)
    One thing I've noticed with these steel draws (in general) is they all seem to be really catious about extended weight on the draws..
    My outback draws have about a 300mm over lap on the draw when fully extended..
    That's a crazy huge amount..
    I'm going to pull mine out and mod it so it has a 100mm overlap and you can actually get stuff out from the back of the draws..
    I'll assume the fridge slide top is the same but not sure how easy that is to mod..
    I stood in my drawers fully open...
    BigRAWesty (15th February 2016)
  6. #54
    yeah but look at the size of you mate! haha, i dont know if the drawers would support the weight of our more "sturdily built" members hahaha
  7. The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
    BigRAWesty (15th February 2016), threedogs (15th February 2016)
  8. #55
    Little bird told me that TJM will soon have a drawer system of their own.
    About time, I say lol
    There must be a way to make a drop down that doesn't cost the earth
  9. The Following User Says Thank You to threedogs For This Useful Post:
    juzzs8 (10th October 2016)
  10. #56
    If it can hold me it can hold anything you put in them.
  11. The Following 2 Users Say Thank You to mudski For This Useful Post:
    rusty_nail (16th February 2016), threedogs (15th February 2016)
  12. #57
    Quote Originally Posted by besp View Post
    PM sent ,if you do build your own,,,,,, cage the fridge in so you can pack gear on top as well.
    You can buy fridge cages, Ill see if I can find a link
    I think these are a great idea,,,,
    http://www.ebay.com.au/itm/Steel-Fri...item20f4f9fc37
    Im sure you could buy a sheet of mesh and do the same thing for a lot cheaper
  13. The Following User Says Thank You to threedogs For This Useful Post:
  14. #58
    175 Post(s)
    When you find one let me know.
    Might replace my solid mdf fridge surround with cage / mesh setup for ventilation reasons...
    Attachment 64866
    Tapatalked from S6
    Attachment 64866
    Tapatalked from S6
    Mate I'd go to Robot buy a sheet of mesh and go from there, might only cost $60 for a large sheet.
    enough to make some covers for the cargo area windows as well ,protect you tint a bit.
    You can buy special clips to hold it all together or just tack weld in a few places.
  16. #60
    MSA make cages. Very expensive though
