24th August 2015, 09:02 AM
#1161
MudRunnerTD
Yeah I reckon I could. I used a hole saw so it's a nice neat hole. Not sure how much would enter there versus the rest of the engine bay though? Will check it out though cheers.
Probably only a little bit more I guess but it would be roosting in off the tyres
Hello from Under Down Under!
24th August 2015 09:02 AM
24th August 2015, 09:20 AM
#1162
taslucas
Isn't that why there's a hole cut there?
My old body mounts allowed the body to hit the frame and steering box on hard hits, and that's with standard shock towers, I was going to cut out the entire hump to install extended shock mounts
The Following User Says Thank You to liftlid For This Useful Post:
taslucas (24th August 2015)
24th August 2015, 09:50 AM
#1163
Moderator
Yeah the shock tower is hard against the body now. Had to manipulate the drivers side a little but all in now.
Check out my Toy -->
Rogue Dung Beetle
24th August 2015, 09:51 AM
#1164
Moderator
Biggest issue for me was how I was going to get to the top nut on the shock but the hole sorts that out.
Rogue Dung Beetle
25th August 2015, 08:07 AM
#1165
I've seen you lebo slingshot liftlid and I'm surprised the body is still attached at all let alone punched through with holes!
tappa lives!
The Following User Says Thank You to taslucas For This Useful Post:
liftlid (26th August 2015)
7th September 2015, 02:02 PM
#1166
Hey Mudrunner just had a quick question about when you moved the primer pump back over to the drivers side (roughly page 110 I think) . Did you take the wring for the water in fuel plug with it or not worry about it? If so, how did you do that. Just about to do the same on mine and after any tips. Cheers.
16th October 2015, 08:07 PM
#1167
Moderator
vocal
Hi mate, sorry I completely missed your post. Sorry for not following you up.
I have run an after market fuel filter for 10 years with a water separator so the wiring is obsolete on mine. Would not be difficult though I would think. Knowing Nissan it probably leaves the loom on the drivers side and goes across the fire wall anyway.
Hope you got it sorted mate/ feel free to ask away.
Rogue Dung Beetle
BigRAWesty (16th October 2015)
25th November 2015, 06:21 PM
#1168
Nah all good mate. Yeah pretty sure it is in the loom on the drivers side and just goes across the inside of the firewall and then out the other. Haven't got around to it yet as have had bigger dramas. Cheers though.
The Following User Says Thank You to vocal For This Useful Post:
MudRunnerTD (25th November 2015)
30th January 2016, 07:33 PM
#1169
Moderator
What have we got here?
48.3 OD pipe. Hmmmmmm
And a nice bender!!!
Time to get busy!
Brush bars for the GQ and GU
Making Sliders for the GU
Tomorrow is going to be a great day!!
Rogue Dung Beetle
The Following 6 Users Say Thank You to MudRunnerTD For This Useful Post:
AB (30th January 2016), BigRAWesty (30th January 2016), jay see (31st January 2016), NissanGQ4.2 (30th January 2016), Plasnart (30th January 2016), Winnie (30th January 2016)
30th January 2016, 08:36 PM
#1170
Moderator
Plasnart
Woo hoo! Are you a stick or mig kinda guy?
Going to mig it. Think I will dump the gasless wire and fit gas wire and small bottle see how I go.
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
mudnut (30th January 2016), Plasnart (30th January 2016)
