Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: How many run an air tank and why ?
    Thomastown, Melbourne
    6 Post(s)
    Those with a tank how have you dealt with the condensation,
    just empty the tank every now and again into a seperate container.
    Either with a spring loaded drain plug or a simple tapered one.
    Might grab the tank [5 gal] out of the Troopy and fit it somewhere on the Patrol.
    I have a hose that runs from under the tank with a tap and empty it out..
  2. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    threedogs (27th January 2016)
    http://www.ebay.com.au/itm/PIRANHA-A...IAAOSwhcJWMc8o
    Heres a small tank to keep the pressure up to your lockers.
    Being square it would fit just about anywhere.
    This is about the cheapest tank I could find,
    maybe its cheaper to buy a SCA 240v one and strip it down
    http://www.ebay.com.au/itm/321240440...%3AMEBIDX%3AIT
  5. #13
    43 Post(s)
    Well fair point td..
    Who said they have to be round??
    Patrol Guru
    Apr 2011
    Melton
    What size tank would be worth while.
    A while back I though out a cheapee compressor due to the pump failing, j sjould have kept the tank
  7. #15
    43 Post(s)
    Quote Originally Posted by GQ TANK View Post
    I would think 6-10L.. so 8 would be perfect lol..
    A 90-130psi switch.. 150 psi relief valve..
    Sorted..
    All the Comp trucks Ive seen only had a 3ltr hotdog tank to run their lockers.
    But if you want to run a rattle gun fit the biggest you can find, I had a 5 gallon
    in my other 4x4, Really up to what space you have available, also if you are
    hard mounting the compressor as well
  9. #17
    They are round so the air can't hide in the corners... maybe someone can also figure out why a boxing "ring" is square
  10. The Following User Says Thank You to the evil twin For This Useful Post:
    BigRAWesty (28th January 2016)
  11. #18
    43 Post(s)
  12. The Following User Says Thank You to BigRAWesty For This Useful Post:
    the evil twin (28th January 2016)
  13. #19
    Expert clubbyr8's Avatar
    Penrith, NSW
    I bought a cheap 240v compressor with tank from Bunnings for less than $50. I think the tank is 9L. The compressor was useless, so I threw it away, but the tank works fine, comes with 100psi switch and two pressure dials. Works for me....
    The compressor is a Spear & Jackson Project Air, I kept the 100psi switch, the safety valve, the inlet and outlet pressure gauges, the pressure regulator and the Nitto connector, pretty cheap imho....
    GROOVY GUVII
  14. The Following 3 Users Say Thank You to clubbyr8 For This Useful Post:
    BigRAWesty (28th January 2016), Skitzyrex (28th January 2016), threedogs (28th January 2016)
