Results 11 to 20 of 22
Thread: OLD 4x4 MAGAZINES HOW WRONG WERE THEY EH!!
    Mar 2013
    NE Melbourne
    ... and the Ranger engines that blow if you don't do the oil changes juuuuust right because the variable flow oil pump won't self prime.
    Forgot about that. My mechanic showed me the service notice Ford had sent out about this issue. I pity the diy guys who will service them after warranty without any idea of the problem.
  2. The Following User Says Thank You to Rock Trol For This Useful Post:
    BigRAWesty (24th January 2016)
    Mate had the motor changed in his 3ltr diesel Hilux,
    faulty injector washers I think it was
  5. #13
    Yeah they have just as bad a reputation as the ZD30
  6. The Following User Says Thank You to Winnie For This Useful Post:
  7. #14
    And getting worse..
    It's just their 3ltrs which have the issue..
    The early v8's are the same but the have changed them..
    His was an 07 model, sadly he had to pay
    There was issues with the Toyjo V8 using oil
    but the oil is like water its that thin
  9. #16
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    They where on the money back then.... The ZD30 is much better engine then a TD42.
    2003 GU SIII Auto Grenade. All the goodies.
  10. The Following User Says Thank You to Softy For This Useful Post:
    4bye4 (24th January 2016)
  11. #17
    Patrol Freak kevin07's Avatar
    georges hall
    We've got a few at work. There not bad to drive apart from the horrible amount of electronics that tries to take over all the time and their stiff as. Had two with exactly the same problem with randomly getting flat batteries (real quick - like within an hour) Been back to Ford countless times who are hopeless. Given up on them just carry a jump starter pack, their nearly out of lease now.
    They've sold like hot cakes, must be a few happy campers out there tho.
    that b
    attery problem is a quick fix find the wire that limits the charging and cut it
    13 y62 the beast that burbles
  12. #18
    194 Post(s)
    Quote Originally Posted by kevin07 View Post
    that b
    I wish Ford knew about that. Went to a few dealers none of them had a clue or admitted they knew of it. After doing a bit of research seems like a common problem you'd think they would do a recall or at least know the fix. . . Glad i didn't buy one of the lemon ones (not that i could afford one). . .
  13. The Following User Says Thank You to Rossco For This Useful Post:
    BigRAWesty (28th January 2016)
  14. #19
    Patrol Guru
    Apr 2011
    Melton
    I remember attending a 4wd club meeting were the local Nissan dealer attended to do a sales pitch on the new, great patrol fitted with a zd30
    the dealer stated that it was the best, most reliable motor that had been put in a patrol.
    Ranger, one of the guys in my club had a ranger that developed a minor engine fault. After he took the ranger to the local ford and a $7000 bill to rebuild the motor. He eventually got ford to foot the bill under warranty
    navara guy in the club blew his clutch at 20,000km -new rubber fly wheel clutch etc - repaired under warranty, failed again at 40,000km. He was looking at a $2200 bill for another rubber flywheel plus the clutch kit. He replace the flywheel with a solid unit $900, plus clutch kit
  15. The Following 2 Users Say Thank You to GQ TANK For This Useful Post:
    BigRAWesty (28th January 2016), Rock Trol (29th January 2016)
  16. #20
    Quote Originally Posted by GQ TANK View Post
    And now Toyota with injector issues..
    No one is safe anymore..
