Results 1 to 10 of 20
Thread: Tb42 missing straight petty carby details inside
    Jan 2016
    Darwin
    Hello all, over the last week my maverick has developed a miss. What i have found whilst the car was running and pulling off leads one at a time is that no4 is not receiveing spark from the dizzy cap. I tried with another lead that i know is getting spark and it did not work . It has new dizzy cap and points new leads and plugs. All the contacts and button look fine to me.
    I am a bit lost as to why only one point would not get spark so next step might be the extended button as per other threads.
    Any hot tips would be appreciated cheers.
    Dont these dizzy's need an extended rotor button ???
    Is there an after market electronic ignition available
    for these set and forget I say
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    The electronic ignition module only replaces the points and still uses the rotor button and dizzy cap so if that's where the problem is then it won't fix it. Having said that, I'd still recommend fitting one. I installed the pertronix flame thrower 2 module and coil and it made a noticeable change in the power and economy.
    Have you checked the spark plug?
    >>>tappin from tassie
    Hello from Under Down Under!
    Jan 2016
    Darwin
    Yes all plugs are fine. No spark from dizzy on one point.
    Aug 2011
    North West Tas
    56 Post(s)
    Can you borrow another dissy cap to try?
    >>>tappin from tassie
    Jan 2016
    Darwin
    I have a brand new dizzy cap. There is continuity between the point inside the cap and the terminal on top where the lead connects. All i can think is my button needs replacing
    Patrol Guru
    Apr 2011
    Melton
    A combination of extended rotor button, pertonix ignition and points do help.
    Have you changed the condenser and coil, as these have been know to cause missfire.
    you have done the rest
    The most common cause of a miss is the leads /Cap/plugs.
    A cracked exhaust just below the manifold can be a cause and loss of powers
    a vacuum leak on the inlet manifold can cause miss
    a loose carby, can cause a miss. Remove the air cleaner grab the top of the carby and give it a shake
    A faulty head or head gasket can be the cause -check the cylinder pressure
  9. The Following User Says Thank You to GQ TANK For This Useful Post:
    Fox7 (4th March 2016)
  10. #8
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by Virgil9 View Post
    Well it looks like you've ruled everything out but that. Strange for the button to only miss on one lead though. Only thing left to do is swap the button I guess
    >>>tappin from tassie
  11. The Following User Says Thank You to taslucas For This Useful Post:
    Virgil9 (24th January 2016)
  12. #9
    Jan 2016
    Darwin
    Yer i think ill just add the 4mm onto my button or buy the extended rotor next. Thanks for the help
  13. The Following User Says Thank You to Virgil9 For This Useful Post:
    taslucas (24th January 2016)
  14. #10
    Patrol Guru
    Apr 2011
    Melton
    I dont think the extension is 4 mm, its around 2mm. I have heard of people extending their existing button. The main improvement is bettle idle, an the motor is a bit more responsive.
    I don't think the rotar would be the route cause.
    Could you have a bent dizzy shaft -I have heard it happening but don't know what the symptoms were
  15. The Following User Says Thank You to GQ TANK For This Useful Post:
