Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Mounting LED light any ideas please
    Jan 2014
    Shepparton VIC
    Mounting LED light ideas please-Update: Mock-up done
    I just received two led lights which I thought to mount it on the roof bars for camping purposes.
    if any of you had a similar or different setup using LED's can you please advice/post a pic which I may make use of the ideas.
    Thanks with regards,
    43 Post(s)
    I'd personally mount them under the bar in that spot. Get them lower oand more protection
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MyGU8 (5th January 2016)
    Jan 2014
    Shepparton VIC
    Good point Westy, thanks.
    X 2 with underneath,,, well protected
    Jan 2014
    Shepparton VIC
    My plan is to bring the wire along the centre pillar and through the existing wire grommets to the dash area.
    But I will need a good wide sticky tape to achieve this.
    Is there anything for this or is there a better way to do the wiring. The only thing I am worried about taking the wire through the door is water ingress during pressure washing.
    I have two of these lights which I am planning to fix on both sides. Is there a switch I can operate light1, light2, and both lights? Like a 4 way switch?
    You can pull the door trim out and run it along the
    channel under those step plates that simply snap on
    I have wires running down the B pillar into the Patrol
    just go easy where the wires enter when you wash it.
    GQ or GU ??
    I use either the yellow plastic from chip board flooring
    or a straightened out coat hanger to "snake" wire through
    difficult areas
    Jan 2014
    Shepparton VIC
    Thanks for the suggestions TD, Mine's a '12 GU. I run my RCA wires for the amp on passenger side step trim so I am fairly familiar with the setup. I noticed the second row door's electrical going through a rubber grommet through the middle pillar but fairly closer to the floor so I need to bring the wires from the roof bars to almost closer to the floor, if I can workout something to stick the wires to the pillars it would be a neat hidden setup as I noticed the pillar is almost always hidden from view. I will see how I go and surely will post a HowTo once finished.
  10. #8
    Sounds good you could run an on/off/on carling switch.
    Would those telecom antenna wire [brackets work]
    They are square about 25mm x 25mm with
    tape on the back you hold the cable in place with a
    small cable tie
    http://www.ebay.com.au/itm/100PcsSel...4AAOSw2s1UtKV3
  11. #9
    Jan 2014
    Shepparton VIC
    Led floodlight mock-up install
    Hi All,
    Just did a mock-up of my led floodlight installation.
    I used 40x40 steel section (not sure what they are , but that's all I had in my shed).
    Hoping to use the same size 3mm thick aluminium angle section for the final.
    I like to have the aluminium section to looks professional, not sure how I am going to achieve this with simple tools.
    What are your thought on the installation guys/gals.
  12. #10
    43 Post(s)
    I'd just drill a hole threw the bar and bolt threw.
