11th November 2015, 05:06 PM
#371
As you have said... " if the motor is already on the way to dropping the pin, regardless of what you do, apart from a rebuild, its going to happen. How do you tell? The only way I think would be to take the head off and look, or a compression test may give an indication that something is not right." but there is a point that I have noticed mentioned on another thread is that if the O2 sensor becomes clogged or fouled, and the boost runs too high, this is the main culprit for things going bang... Is that a reasonable summation?
'05 ST-S with a nice tint and LOTS more to come...
11th November 2015 05:06 PM
11th November 2015, 05:18 PM
#372
Daily Lurker
Biskit
from what my mechanic told me is a combination of a failing injector pump and the maf sensor being dirty look out for nissannewby, he knows wayyy more about that rahter than me
11th November 2015, 07:13 PM
#373
Biskit
Hi boost wont kill these motors. Mine ran on 25psi boost for nearly two years. The o2 sensor your refering to. I would assume its the air flow meter, or the map sensor your meaning.
rusty_nail
It could be a number of things as to why it happens. Each scenario would be slightly different maybe. But from the three stripped down motors i have seen, all suffered the exact same fate. Melted pistons on 3 and 4 pots. What caused this is really unknown. But thoe cylinder temps would have been bloody high for this to happen i think.
8th December 2015, 08:24 PM
#374
Just reads this entire thread, 2 hours later, I gotta hand it to not only rusty for your extraordinary patience , but everyone on here for their unconditional support. I too have recently bought a GU IV and glad to be in the right place with the right people on this forum! Yet to do nads but sorting out some other issues atm (possible oil cooler leak and need to fix my drivers door which doesnt want to lock). Great read, good stuff rusty.
The Following 2 Users Say Thank You to bsteveo For This Useful Post:
rusty_nail (8th December 2015), Sprock (4th January 2016)
8th December 2015, 08:58 PM
#375
Moderator
bsteveo
Imagine the support he"d get if he was a nice bloke!!
Check out my Toy -->
Rogue Dung Beetle
The Following 5 Users Say Thank You to MudRunnerTD For This Useful Post:
Clunk (9th December 2015), mudski (9th December 2015), NissanGQ4.2 (8th December 2015), Rocket55 (8th December 2015), rusty_nail (8th December 2015)
8th December 2015, 09:15 PM
#376
MudRunnerTD
He's gotta be a nice bloke, if I was in his shoes I probably would have lost my crap and burnt the car to the ground by now lol.
#377
MudRunnerTD
But he's right, as venting as loosing your crap is, it doesn't fix grenaded patrols!!
The Following User Says Thank You to bsteveo For This Useful Post:
4th January 2016, 04:34 PM
#378
Daily Lurker
does anyone know how to get the alternator out? im having trouble accessing the bottom bolts on it, is there a trick?
4th January 2016, 09:26 PM
#379
you just need to hold your tounge right Nic. Theres one bolt either side which the alternator pivots on. From memory these were a pain to remove.
BigRAWesty (4th January 2016), rusty_nail (5th January 2016)
4th January 2016, 09:30 PM
#380
Yea it's 3 bolts. I found on the td undo the bottom ones first as the top will hold the weight off the bottom 2 so they undo easier..
